What all do i need if changing gears - JeepForum.com
post #1 of 3 Old 09-18-2001, 10:31 PM Thread Starter
yjman
What all do i need if changing gears i am going to put 4.56 gears in my dana 30 and rear35
yjman is offline
post #2 of 3 Old 09-18-2001, 11:11 PM
Nightclaw
I'd be very leery of putting 4.56's in a D35C, seriously. I killed my D35C with 3.07's, 30" tires and an EZLocker. Now, my axle housing is about as straight as a San Francisco transvestite...
If you want to go ahead with 4.56's in your current setup, you need to know what your current ratios are. If you currently have 3.55's or lower, you will need new carriers front and rear. 3.73's and higher use a different ring gear carrier. This holds true for both front and rear axles.
You'll also need bearings, a shim kit, and appropriate gauges to set your gear backlash. In other words, if you've never set up a differential before, you probably want to take it to a driveline shop and let "the pros" handle it. If you screw up your setup, you'll eat your gears alive in no time - definitely a "bad thing."
Nightclaw is offline
post #3 of 3 Old 09-19-2001, 08:13 AM
RodeoRob
RodeoRob's Avatar
I second the fact installing gears is a difficult process and probably should be left to the pros in less you are very confident in what you are doing. An incorrect gear install will eat things up in a heartbeat.
Even most of the guys i know that are expert wrench turners and DIY mechanics leave gear installs to the professionals.
-Rob
Robert Gorrell
1995.5 Isuzu Rodeo - SAS'd and SOA'd, sitting on 36x12.50 TSLs, D44 front, 14bff rear, locked by OX and Detriot, suspensions by Jeep and Chevy, high steer conversion, 5.13 gearing and Teralow in the case.
RodeoRob is offline
Changing Gears in My TJ ET48 TJ Wrangler Technical Forum 12 11-11-2008 08:52 PM
Im changing my gears out Goobersbro YJ Wrangler Technical Forum 5 10-24-2008 11:03 AM
changing gears liboozers TJ Wrangler Technical Forum 6 04-26-2006 01:20 PM
Changing Gears patphish TJ Wrangler Technical Forum 30 03-20-2006 05:32 PM
Changing gears from 3.07 to 4.11 Baas TJ Wrangler Technical Forum 4 03-17-2005 06:35 AM
