What is this? - JeepForum.com
post #1 of 17 Old 08-28-2013, 01:37 PM Thread Starter
steelydon
What is this?
2 questions. I have never owned a Wrangler and I am looking at a 1995. There is an add-on knob mounted below the dash with a button in the middle. The button must be depressed and the knob pulled out (2 +/- inches) before the 4wd is engaged. I have no idea what this is and the seller bought this jeep to sell so he is unable to provide any information.
This jeep has contoured seats and a 5 pt belt. If I ended up buying this jeep I would change out the seats. What jeep models have interchangeable seats?
Thanks,
Don
steelydon is offline
post #2 of 17 Old 08-28-2013, 01:50 PM
CaptLeeB
Sounds like the knob is a posi lock for the cad in the front axle to engage the front axle. This was probably installed to replace or fix a vacuum problem. It is a pretty common mod you can get more info by searching posi-locker (not to be confused with differential locker.
Seats other similar year wranglers, chevy cavaliers and a few other vehicles will bolt up. Also a lot of info on this. Go under the FAQ for yj sticky or Super Mod Thread also in the stickies you'll find a lot on this.
CaptLeeB is offline
post #3 of 17 Old 08-28-2013, 01:52 PM
SeanB95YJ
my money is on a posi-lock (not to be confused with a locker)
if you follow the cable coming off the back of that knob, I bet it runs to a box (for lack of a better term) on the passenger side of your front axle. pulling the cable slides the shift fork connecting the inner and outer shafts on the passenger side.
original equipment was a vacuum motor, which is a common failure point, so many replace the vacuum shift with a cable mechanism
Sean B. - Schenectady, NY - 95 YJ, 350/700r4/NP241, JB Shorty SYE, 8.8 rear, 2" BDS, 1" homebrew shackles, Daystar 1" BL, TJ flares, 35x12.50 General Grabber AT2 on 15x10 Bart D-Truckers, Polyshield polycarbonate windshield, HD over/under crossover steering
swap/build thread:
SeanB95YJ is offline
post #4 of 17 Old 08-28-2013, 01:53 PM
jserna
1987 YJ Wrangler
That is a Posi-lock knob. It is use to engage the front axle when shifted into 4wd. The factory system uses vac form the engine to engage, however leaks in the system will cause the factory system to fail.
jserna is offline
post #5 of 17 Old 08-28-2013, 01:54 PM
ForestJeep89
The actuator u mention is most likely a posi-loc unit. This unit lets u manually actuate the 4x4 instead of having the stock vacuum system.Do a search on here to find out more about ur particular unit,whether it is homemade or aftermarket produced.
ForestJeep89 is offline
post #6 of 17 Old 08-28-2013, 01:54 PM
asbury
The knob is an aftermarket add on to replace the old unreliable vacuum disconnect for the 4wd
JEEP NAKED !!
asbury is offline
post #7 of 17 Old 08-28-2013, 01:56 PM
Luuca
Typical /f12 Hooligan
Luuca's Avatar
It runs the flux capacitor.
^Best Answer
91 YJ "Alice" 4.0L, AX-15, NP 231 w/HnT Flange, Adams Driveshafts F/R, 2.5" OME 36Rs, 5/8" /f12 Booms, 32" Yoko ATs, 4.10 D30/35 Aussie Lockers F/R
YJOTM never
05 LJ Rubicon "Ghost"
Luck Favours The Prepared
Luuca is offline
post #8 of 17 Old 08-28-2013, 02:05 PM
RICEKILA
Photo ?
I was once a tree house.
I lived in a cake.
But I never saw the way - the orange slayed the rake --
RICEKILA is offline
post #9 of 17 Old 08-28-2013, 02:23 PM
SeanB95YJ
Originally Posted by luuca View Post
it runs the flux capacitor.
^best answer
Originally Posted by ricekila View Post
photo ?
swap/build thread:
post #10 of 17 Old 08-28-2013, 02:26 PM
grandboost98
^Best Answer
Originally Posted by SeanB95YJ View Post
http://kalecoauto.com/index.php?main...products_id=21
And I think all YJ seats are interchangeable as well as a list of other cars
04 Grand Cherokee Overland
72 Chevy Nova-in progress
grandboost98 is offline
post #11 of 17 Old 08-28-2013, 02:45 PM
CaptLeeB
Earlier yj seats had a different base and mount slightly different. But they can be modded easily.
CaptLeeB is offline
post #12 of 17 Old 08-28-2013, 02:51 PM
CrawlingForward
If you do swap out the seats, I'd list them on here. They sound like a good (and expensive) setup that many on here would jump on!
95 YJ, Rio Grande - The Wannabe Sleeper Wheeler
2010 JKU, Islander Edition - The Burly Stock Overlander
Build/Wheel/Break/Educate/Upgrade/Repeat
CrawlingForward is offline
post #13 of 17 Old 08-28-2013, 05:16 PM
RICEKILA
Yep -- thats it
I lived in a cake.
RICEKILA is offline
post #14 of 17 Old 08-28-2013, 07:47 PM
laybackman
Bikini Bridge Inspector
laybackman's Avatar
2010 JK Wrangler
Thanks,
Don
Does the knob look like the one here;
http://www.quadratec.com/products/52435_0X_PG.htm
Do you know what was good about the good old days? I wasn't good, And I wasn't old!
Senators and Congressman should wear uniforms like NASCAR drivers so we could identify their corporate sponsors....
laybackman is offline
post #15 of 17 Old 08-29-2013, 07:13 AM Thread Starter
steelydon
Thanks for the quick and mostly accurate responses. (really Luuca, flux capacitor?). I'm always a bit dubious about add-ons and aftermarket contraptions but it turns out this is a good thing and I appreciate you guys pointing me in the right direction. I pulled the trigger and now I am officially a part of the Wrangler family, God help me. I'm sure I will be back and I hope to be able to contribute.
thanks again,
Don
