What is this?? - Page 2 - JeepForum.com
post #16 of 24 Old 04-18-2012, 05:02 PM
Anticanman
RIP one good jeeper
Anticanman's Avatar
Originally Posted by Cooter92YJ View Post
Mine buzzes when the key is left in the ignition and the driver door is opened! No idea why it would kill the gauges, but the way the wiring schematic is in the Haynes manual, they are all kind of hooked together with the white with black tracer.....
Mine just killed the gauges again this morning until inset the parking brake again and my foot grazed it and my gauges initialized. My problem is the dash lights go out too and I drove 60 miles with the parking brake on because I couldn't see it.
Luck Favours The Prepared
Anticanman is offline
post #17 of 24 Old 04-18-2012, 06:29 PM
wickedoffroad
1987 YJ Wrangler
That is where you can install the Flux-capacitor.
wickedoffroad is offline
post #18 of 24 Old 04-18-2012, 07:17 PM
UltimatE
Resident Audio Guru
UltimatE's Avatar
Its your buzzer. The thing that buzzes when you turn on the ignition.
Its worthless, I unplugged mine and threw it in the trash years ago. No more annoying buzz to tell me to put on my seat belt. (I wear mine 24/7 anyway)
-Matt
White '94 YJ Sport
Green '94 XJ Sport - 57,000 Original miles
UltimatE is offline
post #19 of 24 Old 04-18-2012, 07:20 PM
mrmark
Buzzer? I didn't know there was a buzzer, I guess my Jeep had it removed long ago.
Wave as you pass me :D
The problems of owning 2 Jeeps ... I never know which one to work on or which YJ gets the next mod ...
mrmark is offline
post #20 of 24 Old 04-18-2012, 07:29 PM
G30SFF250
We don't need no stinkin buzzers!
I would rather have a broke Jeep, than no Jeep at all.
G30SFF250 is offline
post #21 of 24 Old 04-18-2012, 09:59 PM Thread Starter
timatoe
timatoe's Avatar
OK, so it's never buzzed, and apparently it is supposed to read to a ground when the key is off as does the brown line to the alternator. Yes I traced out my entire freaking harness today to find it's normal.
My problem was,,,,,,,,, way back when I first bought the Jeep it had a MSD ignition in it and had issues with run on, the PO had a hokey switch to shut it off. I tapped into the switched line and put in a diode so that it couldn't back feed the ignition and cause run on. Anyhow, diode burned up causing no switched 12v. I just pulled the diode and everything seems right now. I won't now till next weekend when I have a new radiator in it so I can fire it up again.
timatoe is offline
post #22 of 24 Old 11-14-2013, 03:41 PM
dpondaco
what is this
I think I may be too late on this, but I believe this part is for the rear window defogger. should be a timer and relay built into it.
dpondaco is offline
post #23 of 24 Old 11-14-2013, 04:53 PM
jaycal3
Hahahaha.... "I think I may be too late" he says... the thread was dead 1 1/2 years ago... Genius!
93 YJ, 6 cyl,3.5" BDS,1" Prothane BL,1/2" booms, 33" Mickey Thompson MTZ on MT Beadlocks.
Do your part for Leukemia research - help find a cure.
KCCO
jaycal3 is offline
post #24 of 24 Old 11-14-2013, 08:26 PM Thread Starter
timatoe
timatoe's Avatar
Could've been. I used to have a hardtop. Plugged it back in, still doesn't buzz.
timatoe is offline
