What is this?? - JeepForum.com
post #1 of 24 Old 04-17-2012, 10:38 PM Thread Starter
timatoe
timatoe's Avatar
What is this??
I hate these types of threads but I have no idea what this is.
I'm in the middle of getting my junk all put back together and was about done today when I found that I didn't have a switched 12v to my gauges, tach, etc.... because well it was shorted to ground. So after pulling the dash all back apart and tracing the entire harness I found that the switched line (white w/black tracer) grounds out only when this box is attached.
Anyhow, what is it? It plugs in directly below the fuse panel.
BTW, I know it's not the flux capacitor, because I already re-located that to the passenger side.
timatoe is offline
post #2 of 24 Old 04-17-2012, 10:55 PM
Anticanman
RIP one good jeeper
Anticanman's Avatar
Honestly, I was gonna ask the same thing. Mine will buzz from time to time and somehow gets a bad connection and I lose my gauges.
I think it's the same part.
Luck Favours The Prepared
Anticanman is offline
post #3 of 24 Old 04-17-2012, 10:57 PM Thread Starter
timatoe
timatoe's Avatar
Yeh, I've never actually noticed it before, but just out of the blue it's shorting out. If I don't need it I'm gonna toss it, but if I do, then obviously I need to find another.
timatoe is offline
post #4 of 24 Old 04-17-2012, 11:01 PM
mrmark
It's a GPS tracker put in by the CIA No idea what it is, try not putting it in and see what happens.
Wave as you pass me :D
The problems of owning 2 Jeeps ... I never know which one to work on or which YJ gets the next mod ...
mrmark is offline
post #5 of 24 Old 04-17-2012, 11:06 PM
imstillatwork
Obviously a set of relays, but what why for how? No idea...
imstillatwork is offline
post #6 of 24 Old 04-17-2012, 11:10 PM
Anticanman
RIP one good jeeper
Anticanman's Avatar
Que would know...
post #7 of 24 Old 04-17-2012, 11:26 PM Thread Starter
timatoe
timatoe's Avatar
Yep, Que for sure. Max likely would too.
timatoe is offline
post #8 of 24 Old 04-18-2012, 08:03 AM
olsqris
Looks similar to this.
http://www.autopartsobsolete.com/82-...-14036201.html
It's a headlight buzzer in this application. I've also seen it as some sort of seat belt alarm/warning in some other links. Seems to be a relay to give some kind of warning when the key is turned on.
olsqris is offline
post #9 of 24 Old 04-18-2012, 08:09 AM
jaycal3
Could it be the buzzer for when your door is open? I had a connector floating around and every time it made contact with metal it buzzed. I taped it up but but never bothered to find out where the actually buzzing was coming from...
93 YJ, 6 cyl,3.5" BDS,1" Prothane BL,1/2" booms, 33" Mickey Thompson MTZ on MT Beadlocks.
Do your part for Leukemia research - help find a cure.
KCCO
jaycal3 is offline
post #10 of 24 Old 04-18-2012, 08:11 AM
Anticanman
RIP one good jeeper
Anticanman's Avatar
Why does it keep the gauges from initializing?
post #11 of 24 Old 04-18-2012, 09:50 AM Thread Starter
timatoe
timatoe's Avatar
http://www.autopartsobsolete.com/82-83-84-85-86-87-88-89-pontiac-firebird-ignition-headlight-buzzer-nos-gm-14036201.html
Yep, looks exactly like that. But it's never buzzed since I've owned it.
I don't know that's what has me baffled. When I test across the ground and the switched lines (on the unit itself) with it unplugged they're not shorted, but when it's plugged in it shorts out.
I'm just going to put the entire thing back together, leave that unplugged and see what happens. There's a half dozen unused plugs behind the dash anyhow.
timatoe is offline
post #12 of 24 Old 04-18-2012, 02:02 PM
veestan
There you go It's a .....
GM Alarm
[]lllllll[]
'89 YJ 4.2L 6cly
'06 H3, don't hate
'01 YZFR6
veestan is offline
post #13 of 24 Old 04-18-2012, 02:19 PM
idskot
STOCK ALARM?!
I think you're pullin' my leg, sir.
idskot is offline
post #14 of 24 Old 04-18-2012, 05:52 PM
Cooter92YJ
Mine buzzes when the key is left in the ignition and the driver door is opened! No idea why it would kill the gauges, but the way the wiring schematic is in the Haynes manual, they are all kind of hooked together with the white with black tracer.....
Cooter92YJ is offline
post #15 of 24 Old 04-18-2012, 06:02 PM
idskot
And for the record, I don't have one.
idskot is offline
