Went wheeling, not sure what I broke - JeepForum.com
post #1 of 9 Old 06-24-2013, 10:01 AM Thread Starter
Fozzybear42
Went wheeling yesterday and noticed late last night that I am now leaking what appears to be some gear oil on the passenger side of the front axle. I know this is very limited info, but I'm trying to get to planning while I'm sitting here at work. Could this be a simple ~$5 seal or is it likely something worse. I was planning on doing a d30 4.10 and 8.8 4.10 swap during the winter in favor of other upgrades sooner but if this is beyond a very simple fix I'll probably just change my priorities and start the junkyard search asap.
Fozzybear42 is offline
post #2 of 9 Old 06-24-2013, 10:05 AM
nixer600
Sounds like a front differential axle seal. Long as the oil is leaking out the axle tube near the knuckle I'd bet that's it.
Sent from AutoGuide.com Free App
nixer600 is offline
post #3 of 9 Old 06-24-2013, 10:12 AM Thread Starter
Fozzybear42
Sorry for being so vague, yeah it's coming out near the knuckle.
post #4 of 9 Old 06-24-2013, 10:37 AM
PA_YJ19
Is ur axle stock? If so u had a 2 peice axle shaft on that side and the one prob leaking is a pain to replace. Ur better off losing the 2 peice axle shaft and upgrading to a one piece shaft from an xj or tj. If u plan on upgrading in the future might as well just do it now and save urself some trouble.
PA_YJ19 is offline
post #5 of 9 Old 06-24-2013, 10:42 AM
pasinbuy
Pretty common for that seal to go. Replace it and do the other one when you do your upgrade.
pasinbuy is offline
post #6 of 9 Old 06-24-2013, 11:28 AM
gtg413i
2003 WJ
I am doing mine this weekend. It is labor intensive and you have to pull out the diff. If you plan to upgrade axles or add a locker, do it all at once. You are fine to drive it, just check that the level is full and top it off until you replace the seals.
Brian's Black Betty Build:
gtg413i is offline
post #7 of 9 Old 06-24-2013, 11:49 AM
jbolty
jbolty's Avatar
There is no reason to take out the carrier when replacing the right side seal unless it is part of a solid shaft conversion. OR, you have one of the very rare set ups with an inner c clip.
jbolty is offline
post #8 of 9 Old 06-24-2013, 11:51 AM Thread Starter
Fozzybear42
Does okay to drive it also mean okay to wheel it? I only ask cause I have a buddy who's been off being a combat medic for the last couple years coming into town in a few weeks and he really wants to go hit a trail or 2. Probably nothing crazy, just some light wheeling. Think I'll be alright if i pay close attention to the level?
post #9 of 9 Old 06-24-2013, 11:56 AM
CrawlingForward
Oh yeah, totally cool to wheel with. Hell, many of us have been running for years with it leaking, ha ha. It's a total PITA to replace, and as long as it's not gushing out, it's fine.
95 YJ, Rio Grande - The Wannabe Sleeper Wheeler
2010 JKU, Islander Edition - The Burly Stock Overlander
Build/Wheel/Break/Educate/Upgrade/Repeat
CrawlingForward is offline
