Went into the river and died - JeepForum.com
post #1 of 13 Old 01-14-2014, 04:52 PM Thread Starter
Eagosspr
Greeting from PR fellow Jeepers!!!
Last weekend my friend and I went offroading and
I went to cross a river and before I knew it my Wrangler 1995 stalled...
We took it out and everything was okay enginewise.
The problem was there was no electricity running thru the jeep I we have been
Killing ourselves trying to fix it and we wonder if it could be
the ECU any opinions???
Any help would be great!!!
Thanks
Eagosspr is offline
post #2 of 13 Old 01-14-2014, 07:05 PM
kloppk
You say "no electricity"
Does anything work? Headlights? Brake Lights?
Do any of the dash idiot lights go on when you turn the key to from Off to Run?
Baystate Jeepers
Deep Woods Extreme
New England 4 Wheelers
kloppk is offline
post #3 of 13 Old 01-15-2014, 12:06 AM
plumber1
Anything like this
I can quit drinking anytime I want, but hey I'm no quitter :)
White Jeep Club #224
plumber1 is offline
post #4 of 13 Old 01-15-2014, 12:07 AM
plumber1
plumber1 is offline
post #5 of 13 Old 01-15-2014, 04:17 AM Thread Starter
Eagosspr
Kloppk
Yes no electricity what so ever!!! No brake , dash light nothing! And the batterry is 100% brand new optima.
Plumber1
Yes exactly luke that maybe 2-3 more inches higher...
Eagosspr is offline
post #6 of 13 Old 01-15-2014, 07:30 AM
jaycal3
You went through that much water and didnt hydrolock? You say everything was "ok engine wise"... what did you check? I cant imagine you not getting water in the engine unless you are snorkled... I would assume you got water in a lot of electical parts that dont play nice with water.
93 YJ, 6 cyl,3.5" BDS,1" Prothane BL,1/2" booms, 33" Mickey Thompson MTZ on MT Beadlocks.
Do your part for Leukemia research - help find a cure.
KCCO
jaycal3 is offline
post #7 of 13 Old 01-15-2014, 02:49 PM Thread Starter
Eagosspr
No water in the engine for sure and im just guessing but can the ECU be fried?
Eagosspr is offline
post #8 of 13 Old 01-15-2014, 05:30 PM
bigbossd1030
Did you pull the plugs and check the cylinders? The dist doesn't react to water very well.
And it is possible the ecu got messed up. That much water and I'm just guessing nothing is siliconed under the good right? If you haven't pulled the plugs yet, do so.
/l ,[____],
l----L-[]lllllll[]-
()_)-()_)--o)_)
OFFICIAL JEEPER
Any Jeepers in Edmonton, AB
I am on channel 33.
I live, I ride, I am JEEP.
bigbossd1030 is offline
post #9 of 13 Old 01-15-2014, 05:35 PM
Mobile_Homie
Desert Rat
Mobile_Homie's Avatar
I dunno, although I have never been that deep, I have looked at the air cleaner intake and I thought it looked good go up to the top of the fenders...
Imma go look again.
Mark
Smoke em if you got em!
Mobile_Homie is offline
post #10 of 13 Old 01-15-2014, 05:37 PM
bigbossd1030
Originally Posted by Mobile_Homie
I dunno, although I have never been that deep, I have looked at the air cleaner intake and I thought it looked good go up to the top of the fenders... Imma go look again.
the hole is at the bottom of the box. I believe it's just below the headlight or level with it.
/l ,[____],
l----L-[]lllllll[]-
()_)-()_)--o)_)
OFFICIAL JEEPER
I am on channel 33.
post #11 of 13 Old 01-15-2014, 08:13 PM
YJ475
Did you check the battery connections? What about the ground connector on the engine block?
YJ475 is offline
post #12 of 13 Old 01-16-2014, 09:07 AM
Que89YJ
No power to anything is the battery connection. Remember that your ground is every bit as important as the power so check it and make sure its good. You can use a set of jumper cables to bridge the battery to the PDC and the battery to ground.
Que89YJ is offline
post #13 of 13 Old 01-16-2014, 10:18 PM
JohnnyZJ
like these guys said.
sounds battery
07' JKUR rollin on 35s
JohnnyZJ is offline
1995 , ecu , electrical issue , water damage , wrangler
