Well even direct from mopar weather stripping don't fit - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > YJ Wrangler Technical Forum > Well even direct from mopar weather stripping don't fit
Ruffstuff 10 year saleBDS 4-1/2" Suspension Lift Kit - Jeep Wrangler YJRough Country Lift Kits and Parts!
Unread 07-20-2013, 06:12 PM   #1
metalhead
2011 WK
I have had nothing but problems trying to replace the weather stripping on the passenger side full steel door on my 94 wrangler. Quadratec sent me 2 weather strippings and both were still about 3 inches too big. So I bought weather stripping from the jeep dealership I work at and it is still 3 inches too big. So I guess I'm down to cutting it shorter and gluing it back together. Does anyone know the name of the glue that you can get for weather stripping?
Thanks
metalhead is offline   Reply With Quote Quick reply to this message
Unread 07-20-2013, 07:04 PM   #2
rubisean
yes it is called 3M super weatherstrip adhesive...... you are doing something wrong, are you stretching it too far? Start at the top corner at the apex of the roof and the windshield frame and work your way around. that is the best i can tell you
rubisean is offline   Reply With Quote Quick reply to this message
Unread 07-20-2013, 07:16 PM   #3
superj
1987 YJ Wrangler
it fit perfectly for both my doors. from 4wd parts or morris4x4
I don't feel like working on anything, at this time.
superj is offline   Reply With Quote Quick reply to this message
Unread 07-20-2013, 07:26 PM   #4
metalhead
2011 WK
I started at the square part of the door. It fits perfect going down the hinge side of the door. Once you work your way around to the latch side of the door it does not fit right. The plastic clips do not line up with the holes in the door. I am not stretching it in any way. I set the squared off corner on the hinge side first and just work it around from there and it seems like it is 3 inches too long.
Unread 07-20-2013, 07:33 PM   #5
superj
1987 YJ Wrangler
hmm, that's odd
Unread 07-24-2013, 09:56 AM   #6
PJGC
I have replaced the seals on both doors of my 95 with seals from OMIX ADA and they fit perfectly. You do have to use 3M super weather-strip adhesive that rubisean mentioned to hold the seal to the door and prevent any water from seeping in behind the seal.
PJGC is offline   Reply With Quote Quick reply to this message
