welding ques. - JeepForum.com
post #1 of 12 Old 05-05-2010, 08:14 PM Thread Starter
newyj
welding ques.
do I need to do anything special for electronics to weld on my frame, ie disconnect battery?
wave back dammit, don't leave me hangin!
yes, I wave at night too
newyj is offline
post #2 of 12 Old 05-05-2010, 08:17 PM
ImpactFabWorks
I like to disconnect the battery just as a precaution. it only takes an extra minute
1990 YJ = The Toy/ My Daily Driver
1996 XJ= Wifes Daily Driver
Please fill out your profile, It helps us help you!!!
ImpactFabWorks is offline
post #3 of 12 Old 05-05-2010, 08:18 PM Thread Starter
newyj
thanks brian, gotta weld near steering box frame rot who knew?
newyj is offline
post #4 of 12 Old 05-05-2010, 08:27 PM
rustywrangler
Got my eye on you.....
rustywrangler's Avatar
You can if you want but I have never, nor did the guy that taught me how to weld.
As long as your ground is close to your work, there should be no issue at all. Exhaust shops weld on rigs all day long without cutting the power.
Congenital Heart Disease is a reality for me, BOTH of my children have it. Please read up and become aware for future generations
Lydia Ann-Acquired 08/05/05 Open Heart surgery 08/10/05
Jacob Patrick-Acquired 01/17/08 Open Heart surgery 02/15/08
rustywrangler is offline
post #5 of 12 Old 05-05-2010, 09:03 PM Thread Starter
newyj
thanks rusty you guys are gods
newyj is offline
post #6 of 12 Old 05-05-2010, 10:52 PM
timatoe
timatoe's Avatar
I never have either. I see it as a precaution you could certainly take but I don't think it's necessary.
timatoe is offline
post #7 of 12 Old 05-05-2010, 11:23 PM
Bigboyky
quoted for truth! I have never disconnected the battery. Just do as Rusty says.
1995 4.0l, 5spd., 4:88's, ARB's F/R, 4"RC lift, homebrew bumpers & tire carrier, homebrew gas tank skid, lined inside, Cobra cb, smitty winch, 130w & 55w Hella lights
Envy our past, Fear our future Go Cats!
Take a look at our club
& here on JF
Bigboyky is offline
post #8 of 12 Old 05-05-2010, 11:29 PM
notmyj
Disconecting the battery does nothing but isolates the battery. It does nothing to protect the sensors or ECM. If you wanted to "protect" them, you would have to unplug and remove them. However, this is not needed. Electricity is lazy, in that it will take the easiest path to ground. If you keep the ground clamp close to the work, the electricity will never make it to anything else.
So, to answer your question. No I never disconect the battery on anything I am welding. But i keep my ground clamp close to the work.
If it has tracks, tires or tits, its gonna cause a problem.
"Everytime someone "upgrades" a D35, an angel looses its wings."
"Dizzy" - What SnoopDog would call a Distributor if he was a mechanic. I cringe every time I hear this moronic term
Originally Posted by Warren Zevon
Send lawyers, guns and money. The **** has hit the fan...
92, 4.0, AW4, 8.8, D30, 15x10, 37's, SOA etc, etc
92, 2.5, 30, 8.8, 4.88, Locked, Winch, 15x8, 35's, 3.5" (RIP)
notmyj is offline
post #9 of 12 Old 05-05-2010, 11:32 PM
bigsquat
i disco when i weld. i blew an ignition modual on a dune buggy by not discoing. and i was grounded right next to where i was welding. just be carefull when you disco some vehicles that have anti theft devices.
red 92 yj,4.0,dana 44 rear,xj driveshaft,rubi 4-1 tc,35"tires,smitty built winch,oba, 6" flares,hand throttle,aussie's front and back,posi-lock,6" lift.anti-wrap, hombrew bumpers, rack and sliders,cb,rear shock truss <>< ,MY BUILD:
Two fish swim into a concrete wall. One turns to the other and says 'Dam!'
bigsquat is offline
post #10 of 12 Old 05-06-2010, 07:28 AM
jeep795
If you have a winch be sure to disconnect those cables as well. Precautionary measures of course. I always disconnect, just for peace of mind.
jeep795 is offline
post #11 of 12 Old 05-06-2010, 09:44 AM
Que89YJ
It is EMC! Electrmagnetics. The electronics are protected when the are not pligged in(for the most part) because the transistors are not stiching and the othe other electronics dont have current flow. Add trons to the picture and have the electronics up and you have a huge recipe for letting smoke out that will now go back in. For the most part everything powers down on the YJ with the Key off. So its not as big a deal, but I guarantee that on the new cars the battery is disconnected when battery power is the only thing going to a module on the car and it cost $1000 to replace! I let the smoke out for a living doing Electromagnetics and if the only thing I loose is 5 minutes diconnecting it and it lessens the chance of the carnage I see here at work....I'll spend the time
Que89YJ is offline
post #12 of 12 Old 05-06-2010, 03:39 PM Thread Starter
newyj
thanks for all the input guys what would we do without you
newyj is offline
Driveshaft Ques. sprad42183 TJ Wrangler Technical Forum 7 02-03-2010 01:43 PM
yes another gear ques. dazed TJ Wrangler Technical Forum 4 02-10-2006 09:51 AM
Air Conditioning Ques SurferJeep88 TJ Wrangler Technical Forum 4 10-08-2005 08:27 PM
Another lift ques. tanriogrende YJ Wrangler Technical Forum 6 04-01-2005 07:29 AM
350 or 4.3 swap ques.... 87yjNY YJ Wrangler Technical Forum 21 07-22-2003 10:03 PM
