Welding Hex onto Torx - JeepForum.com
post #1 of 4 Old 07-29-2010, 11:03 AM Thread Starter
Beerlover
2005 WK
Just a quick question about welding hex nuts onto torx.... Do you guys use the little 110 mig welders for this or does it require a bigger buzz box. I don't have any welding experience and thought if this was a 110 mig job it might be a good learning experience and also a good way to get rid of all the cursed torx bolts.
Would a 110 be strong enough to weld a nut onto a broken off skid plate bolt for removal?
93 YJ, 4.0, Auto, 4" RC, 33's
Beerlover is offline
post #2 of 4 Old 07-29-2010, 11:07 AM
DickeyeFab
Sure, just remember 3 things. No extension cord, good welder, and shielding gas.
DickeyeFab is offline
post #3 of 4 Old 07-29-2010, 02:18 PM
muddy93
1987 FSJ Wagoneer
I've used my little 110v flux core welder to do that, and it worked just fine.
maroon 1987 Grand Wagoneer. stock for now...
muddy93 is offline
post #4 of 4 Old 07-29-2010, 02:26 PM
little_Jeep
I saw a guy who bent a 5-6 inch long round bar into an "L" shape and welded it inside the torx head to remove the torx bolt.. only down side was you needed room to spin the "L" around until the bolt was out... for example, this technique would work on torx bolts on tailgate, but not around roll bar. My thinking is, as a newbie welder, you may want to start with "L" brackets before you move to welding hex nuts as the "L" brackets maybe easier hold into place as you weld.
little_Jeep is offline
Welding nut head to a stripped torx bolt CGIBBS10 TJ Wrangler Technical Forum 42 07-23-2010 01:55 AM
torx help nj95yj YJ Wrangler Technical Forum 5 03-26-2009 12:22 AM
Where to buy Torx aviator TJ Wrangler Technical Forum 14 04-13-2005 08:32 AM
Torx!!!!!!!!!!!!!!!!!!!!!!!! Rudi TJ Wrangler Technical Forum 12 09-16-2004 08:42 PM
torx sux Brack YJ Wrangler Technical Forum 17 01-12-2003 11:40 PM
