Welding Front perches on caster? - JeepForum.com
post #1 of 2 Old 06-03-2003, 11:06 PM Thread Starter
bigsteve3184
bigsteve3184's Avatar
How are the front perches welded? On the driverside you have to grind back one of the arches on the perch to fit it onto the axle correctly. But that part is cast...and I was told you can't weld to cast.
95 YJ 2.5L
SOA/2" BDS Springs/ 1" body
D44 ARB/Ford 9" Detroit Locker/5.13/ 36's
www.novajeepers.com
bigsteve3184 is offline
post #2 of 2 Old 06-04-2003, 10:09 AM
TommyJeep
TommyJeep's Avatar
You can weld to cast, but it won't be as strong as welding to cold-rolled. When I did my SOA, the drivers side perch sits half on the tube, half on the cast. I welded to the cast and it never failed me.
TommyJeep is offline
Welding perches on 8.8 Duncan71 YJ Wrangler Technical Forum 2 06-20-2009 07:56 AM
Welding spring perches and shock mounts Robbypfd YJ Wrangler Technical Forum 2 09-13-2008 06:49 PM
Welding on perches sequel YJ Wrangler Technical Forum 5 10-03-2006 12:04 PM
Welding on lower spring perches?? mrbigglesworth YJ Wrangler Technical Forum 5 01-11-2006 02:49 PM
osburn, i welded my front perches at JYRUS YJ Wrangler Technical Forum 5 02-27-2002 06:36 PM
