Welding a dana 30 - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > YJ Wrangler Technical Forum > Welding a dana 30
Premium LED Lighting by VISION X, Proudly sold at ROCKRIDGBds fox ipf 2.0 racing series shocks now available at rockEngo winches available at www.rockridge4wd.com! Free shipp
Unread 07-13-2014, 11:05 PM   #1
Bighaydn
Welding a dana 30
So I recently put an 8.8 in my yj and my plan is to put a dana 44 in the front end but that's a ways away. My question is I've been pondering to weld up my front end. I also deleted my vacume acuator with a cable engage and I looked in and saw it worked. I'm thinkin of I weld up my spider gears I should have open differential until I engaged that cable. Am I right? I'm just not sure. And if I'm not will it handle way worse with a welded front end? Thanks
Bighaydn is offline   Reply With Quote
Unread 07-14-2014, 05:36 AM   #2
Kick
Yes you are correct open diff until you engage other axel shaft with cable
95 yj 4 lungs 3.5 bds more shackles ox locked 32" BFG AT KO patriot 9500 sye
08 unlimited rubicon 1"3/4 daystar lift
Kick is offline   Reply With Quote
Unread 07-14-2014, 09:48 AM   #3
JohnnyZJ
JohnnyZJ's Avatar
it will work but as soon as you put it in 4wd it will be fully locked and a pain to do just about anything.
92 YJ ~ stage 1; 33" super swampers, 4" lift locked 5 yr plan is 8.8/44 and 37s
RIP 95 ZJ ~ 33s built/longarmed/locked/awesome Feb 2014 ZJOTM winner
JohnnyZJ is offline   Reply With Quote
Unread 07-14-2014, 12:15 PM   #4
The_Goob
Hell on Wheels
The_Goob's Avatar
they call that the poor mans selectable. you can drive in 3wd that way too. however snow driving will become stupid if you get snow there. better off in 2wd until you get stuck
-- Hell on Wheels -- My YJ Build Thread
-April '14 YJOTM-
The_Goob is offline   Reply With Quote
Unread 07-14-2014, 09:19 PM   #5
Bighaydn
Ahhh nice! I thought so when I was looking at That ring and how it came over both shafts that's great to know! What do yiu mean by snow? Does a front locker crap out In snow? I had a detroit on my dana 35 until it blew out and I'd slide all over
Unread 07-14-2014, 10:09 PM   #6
Michaelgoesrawr
Michaelgoesrawr's Avatar
I wouldn't do it solely on the dent it could put in the resale value.
Michaelgoesrawr is offline   Reply With Quote
