this welder? - JeepForum.com
post #1 of 22 Old 01-22-2010, 08:32 PM Thread Starter
white_elephant
this welder?
- Harbor Freight Tools - Quality Tools at the Lowest Prices
is this a good deal? i got a coupon for 82.99 $
1991 jeep yj 2.5
EXPERIENCE ISNT BOLT ON
I DONT GO FAST, I GO ANYWHERE
white_elephant is offline
post #2 of 22 Old 01-22-2010, 08:34 PM
msprooch
I would spend 83 bucks on strippers it will last longer.
msprooch is offline
post #3 of 22 Old 01-22-2010, 08:36 PM
mrspradlin
one of my workers brought his in to fix a plate on a trailer.
Its total hot garbage.
Save and get a good one that will last years
2013 JK Unlimited Freedom Edition
4" superlift 35s
mrspradlin is offline
post #4 of 22 Old 01-22-2010, 08:39 PM
Fhajad
230 volt, plzkthx.
Fhajad is offline
post #5 of 22 Old 01-22-2010, 08:42 PM
1998zj
POS, DO NOT BUY! Save your money and buy a name brand welder. You will be much happier. My buddy bought a HF welder and it couldn't generate enough heat to weld anything heavier than sheet metal.
"Our lady of blessed acceleration don't fail me now"
1998zj is offline
post #6 of 22 Old 01-22-2010, 08:44 PM
rovermil58
idk..i would save up and get something a little more high quality..i dont have alot of experience with welders from harbor freight but i know a weld is something extremely important and you want it to be done right not half asked..just from my experience i would get something with a bit more quality
rovermil58 is offline
post #7 of 22 Old 01-22-2010, 08:45 PM
Apollo12227
It really depends on what your looking at doing with the welder... I've used the harbor freight pinch-a-penny welder before, it will REALLY work well for tack welding thin metals... its more of an "around the house" welder than a shop welder. I used it to tack on some spring purches so I didnt have to drag the stick welder outside and it did the job of holding the purches still for me while taking the rear end back out...
If your going to be doing extremly small jobs with thin metal, to be honest, this welder will work just fine, but your not going to be able to get it hot enough to weld quarter inch steel or anything like that.
There simply isnt enough power comming from the welder to bet anything important on, especially when it comes to your jeep.... Your not going to be able to melt metal of any size quick enough to get penetration of any strength at all. I would hate to see you weld on a rear end with it but again, for small thin metal jobs it will work great.
Apollo12227 is offline
post #8 of 22 Old 01-22-2010, 08:49 PM
Joe Dillard
Electric Chair Operator
Joe Dillard's Avatar
I would be looking for something more like this:
175 Lincoln Mig Welder new in box never opened
Or maybe this:
LINCOLN ELECTRIC WELDER LIKE BRAND NEW
For a 110V here's a real nice one!
LINCOLN WIRE FEED WELDER
Joe Dillard is offline
post #9 of 22 Old 01-22-2010, 08:51 PM
Apollo12227
Or maybe this:
Here's a real nice one!
Now there's a thought... Way to save the day again Joe!
post #10 of 22 Old 01-22-2010, 08:55 PM
Joe Dillard
I like to try to help other members.
post #11 of 22 Old 01-22-2010, 08:57 PM
YJake
Buy name brand stuff from Lincoln, Hobart, and etc.
I've welded all kinds of goodies with my Lincoln 140. If you have a torch and heat stick you can pre-heat and weld really thick stuff and still only run the welder off of a 110 outlet I hardly ever trip the breaker while using mine. I made the welder it's own outlet and everything
Jake
/l , [____],
l---L--[]lllllll[]-_
()_) ()_)==@=)_)
Originally Posted by clemsonfan16 View Post
The 4banger only whines because it wants more!
Originally Posted by Opihi59 View Post
3 Things to know about the forum: Always PB blaster, Always check the FAQ, Always do a search, and if none of that works, ask Mean Max.
YJake is offline
post #12 of 22 Old 01-22-2010, 09:23 PM
RikRotorhead
I bought that welder when it was on sale for $69 and I had a 15% off cupon too. Couldn't pass it up.
I'm glad I bought it. I use it all the time around my ranch. It's convenient that it only requires a 110volt outlet.
But it's only for small stuff. I've welded fenders, a muffler, made a wrought iron gate, welded racks in the tack room, etc... Great small job welder for the money.
It's not junk, but it is good for what I bought it for. I have a 230amp 220volt arc welder for the heavy metal stuff.
Zombies hate fast food.
RJC#512
RikRotorhead is offline
post #13 of 22 Old 01-22-2010, 09:33 PM
skeeterbeater
Or maybe this:
i have one similar to the last one. i would't build a cage with it but it works great for everything i do.
its not the biggest baddest rig on the trail, but i beat the hell out of it and have a good time.
skeeterbeater is offline
post #14 of 22 Old 01-22-2010, 09:35 PM
4.7stroker
I have the Dual Mig 150 the big brother 220v version. I have used it for the past 3 years and I must say everything I put together with it stays put together. My welds are not pretty but I put that down to my lack of skill and the flux wire and not the capability of the welder. If you are a weekend warrier with a limited budget it will work for you as long as you do not want to weld 1/4 plate in a single pass with 95% penetration.
Grinders can make the most amatur looking weld look pretty.
Dwayne
[url]
Prevent Flat Tappet Cam Failure.
[url]
4.7stroker is offline
post #15 of 22 Old 01-22-2010, 09:40 PM
Martinsc
There is one in my area that looks to be the same exact one. Do you think that it is worth it? I would really like to learn how to weld but don't plan on doing any huge projects.
Here it is- Lincoln Welder
My Build-
Martinsc is offline
on board welder 102joe YJ Wrangler Technical Forum 16 04-28-2013 05:04 AM
choosing welder ceichicon TJ Wrangler Technical Forum 1 11-22-2009 07:17 PM
Just got a welder! ufatbastehd YJ Wrangler Technical Forum 7 05-05-2008 06:44 AM
On-board Welder? CO_crawler TJ Wrangler Technical Forum 1 02-16-2008 08:59 PM
What welder to get? MasterD TJ Wrangler Technical Forum 4 05-03-2006 08:51 PM
