welded front end - JeepForum.com
post #1 of 22 Old 11-03-2009, 08:41 PM Thread Starter
ImpactFabWorks
welded front end
ok so the po welded the spider gears in the front. will it even be possible to just replace the spider gears or will i have to change the whole carrier?
1990 YJ = The Toy/ My Daily Driver
1996 XJ= Wifes Daily Driver
Please fill out your profile, It helps us help you!!!
ImpactFabWorks is offline
post #2 of 22 Old 11-03-2009, 09:37 PM
srlbotanical
You will most likely need a whole carrier...
Did you pull the cover and take a look? Most of the time, the spiders are welded to the carrier and you will need to replace everything.
Two Trackers 4WD Club
Wheeling in West Michigan for over 35 years.
HIGHER POWERED!!
srlbotanical is offline
post #3 of 22 Old 11-03-2009, 09:39 PM
bigsquat
the answer is no. the side gears stick in and would make it impossible. even the conical shape of the back of the spiders would prevent it.
red 92 yj,4.0,dana 44 rear,xj driveshaft,rubi 4-1 tc,35"tires,smitty built winch,oba, 6" flares,hand throttle,aussie's front and back,posi-lock,6" lift.anti-wrap, hombrew bumpers, rack and sliders,cb,rear shock truss <>< ,MY BUILD:
Two fish swim into a concrete wall. One turns to the other and says 'Dam!'
bigsquat is offline
post #4 of 22 Old 11-03-2009, 09:39 PM
Apollo12227
It depends... Probably not you need to pull the carrier, pull that center pin out of the spider gears and see if you can brel em' loose so they tumble... It saves you 75 bucks if u can get em' out... If the center pin was welded then u may be out of luck... Take some pics and let us see the damage if 75 bucks is worth ur time.
Apollo12227 is offline
post #5 of 22 Old 11-03-2009, 09:40 PM Thread Starter
ImpactFabWorks
I haven't pulled it yet. i have to drive it tomorrow so i didn't want to drain it yet. I only know because the previous owner told me and i hate it. i want to get rid of the vaccum disco but i can't with it welded like it is. driving it on the street with it locked is brutal
post #6 of 22 Old 11-03-2009, 09:42 PM Thread Starter
ImpactFabWorks
ok i figure either way i will just get a new carrier. will an xj carrier fit? theres tons of xjs at the junk yard but i have yet to see a single wrangler
post #7 of 22 Old 11-03-2009, 09:42 PM
Apollo12227
Lol nevermind it would definatly be easier to replace the carriers I've seen people burn out the enterior of a welded carrier but since u have to but new spiders anyway might as well replace the whole thing.
post #8 of 22 Old 11-03-2009, 09:48 PM
Apollo12227
Yes xj axles are pretty much the same as yj... You can interchange.
post #9 of 22 Old 11-03-2009, 09:53 PM Thread Starter
ImpactFabWorks
I'll just pull the carrier when i got to get the shafts then. i plan on using a one piece shaft so i just want an open carrier. hopefully a selectable locker in the future
post #10 of 22 Old 11-03-2009, 09:57 PM
Apollo12227
Definatly the way to go. I've got TJ long axle on my passanger side and I love it! It's the only way to go when getting rid of that freaking vaccum.
post #11 of 22 Old 11-03-2009, 10:00 PM Thread Starter
ImpactFabWorks
mines ridiculous. the po did a lot of things i don't understand. he completly took out all the vaccum lines from the t-case to the vaccum disco. so i have had to pop the hood and switch over vaccum lines manually to lock and unlock it. and i have had enough of that
post #12 of 22 Old 11-03-2009, 10:51 PM
bigsquat
you could for now just hook up a solenoid of an 90 or older jeep that was used for smog purposes. just hooh full vac to on side and the other side to the disco. just wire to an electric switch on the dash and you have contoll at your finger tips
bigsquat is offline
post #13 of 22 Old 11-03-2009, 10:53 PM Thread Starter
ImpactFabWorks
thats actaully a great idea and now i feel like an idiot seeing as how i have some sitting in the garage
post #14 of 22 Old 11-03-2009, 10:58 PM
bigsquat
i kind of wish i did that b4 i did my posi-loc cable set up. with the welded spiders and the axle disconected it gets a little harry when on ice with 3 wheel drive
bigsquat is offline
post #15 of 22 Old 11-03-2009, 10:59 PM
bigsquat
oh ,i see you have a 90, you have more problems than the disco then! lol
bigsquat is offline
Front axle spider gears welded, DD yjjeepn92 YJ Wrangler Technical Forum 10 11-15-2009 08:46 AM
The 8.8 is welded sequel YJ Wrangler Technical Forum 6 10-12-2006 01:33 PM
welded front murgg YJ Wrangler Technical Forum 8 09-29-2006 12:51 PM
welded D30 murgg YJ Wrangler Technical Forum 26 12-04-2005 02:50 AM
osburn, i welded my front perches at JYRUS YJ Wrangler Technical Forum 5 02-27-2002 06:36 PM
