Weird Wiper/Turn Signal Problems - JeepForum.com
post #1 of 6 Old 10-27-2010, 08:25 PM Thread Starter
OnlynAYJ
Not sure if this has been addressed before I researched it for some time to no avail.
Problem: One of the clips broke off my original turn signal switch, so when I engaged the left turn signal it would not automatically cut off when the wheel turned back right. After replacing the original switch with a replacement from the junkyard, I robbed one off of a early 90's XJ, it that I had fixed the problem. Several weeks later I have found myself with no turn signals, but one of the hazard lights work. Why only one works instead of both I have no idea. Also, I have no wipers without the intermittent box plugged in, and when I plug in the intermittent box my wipers act as if they are set on the slowest speed. However, the wipers will work when using the windshield washer. I don't necessarily think the problems are directly related seeing as there is a wiper switch and a turn signal switch, but it seems odd that they went out at the same time. I'm thinking I have picked up a bad turn signal switch and have an unrelated wiper problem, but I wanted to pick the minds of the JF members before I start buying unnecessary parts.
75% of the planet is covered by water. The rest is covered by Jeep
OnlynAYJ is offline
post #2 of 6 Old 10-27-2010, 09:04 PM
Shamrock84
sounds like u got an electric problem, chief. don't think any research is gonna help, i think you gotta either backtrack what you fixed, see if you caused it and keep on down the line. process of elimination. good luck these gremlins are a pain in the a*s
Shamrock84 is offline
post #3 of 6 Old 10-27-2010, 09:38 PM Thread Starter
OnlynAYJ
Yeah thinking about snagging another turn signal switch and going from there. Thanks for the help.
OnlynAYJ is offline
post #4 of 6 Old 10-28-2010, 05:00 AM
dodger889
Check your plugs. Has far as the wiper goes remove the delay box and see if they work that way. now you will not have the delay part but they should work off, low and high. Why not get a new switch for the turn signals from a parts store?
A 89 yj with a 4.0 aw4 sye out of an 92xj. Now the hard part is done time to get it up in the air just a bit. Working on 8.8 with 3.73 and lsd for the rear. and new D30 hp with 3.73 .
For those who have not figured this out I'm old school but can handle the new too.
Originally Posted by bigsquat View Post
im just cheap, and cheap makes you creative.
dodger889 is offline
post #5 of 6 Old 10-28-2010, 07:56 AM Thread Starter
OnlynAYJ
Price, most of the auto parts stores carry them for $100 but I've found that 4wd sells them for 40. Logically it would make more sense to buy the $40 new one than to continually spend $6, junkyard price, on switches that may or may not work. With the delay box out I'm getting nothing.
OnlynAYJ is offline
post #6 of 6 Old 10-28-2010, 05:57 PM
dodger889
You did plug the two connectors back in to each other. The ones that plug into the delay box?
MMM check this out. 34.95 not a bad price. This is the same as yours.
Turn Signal Switch | 1994 Jeep Wrangler 4WD 4 Cylinders P 2.5L MFI | AutoZone.com
turn signal, light switch, and wiper problems.. Meep97 TJ Wrangler Technical Forum 2 08-12-2010 09:15 PM
Really Weird! Help Me Out! Turn Signal Issue CONNOR_99TJ TJ Wrangler Technical Forum 5 06-20-2010 05:26 PM
turn signal and wiper not working traab007 TJ Wrangler Technical Forum 4 05-14-2009 07:35 PM
turn signal wiper arm control Neighborbill YJ Wrangler Technical Forum 0 04-22-2009 06:32 PM
wiper/turn signal lever StuckInMud94 YJ Wrangler Technical Forum 3 08-06-2005 10:49 AM
