weird windshield leak - JeepForum.com
post #1 of 4 Old 04-04-2013, 11:10 AM Thread Starter
kjg26
kjg26's Avatar
So I was driving in a nice torrential downpour earlier today and noticed a funny leak at each lower corner of my windshield. Water was coming through at a fairly steady pace. Assuming the windshield frame isn't rusted out, should having new windshield seals put in fix this problem?
Black 1993 YJ 4.0, 5 Speed
Slowly but surely getting better and better. Trailer build soon!!
kjg26 is offline
post #2 of 4 Old 04-04-2013, 11:22 AM
ziebartrob
If the water is coming in from between the rubber and the glass it can be fixed by back-filling with urethane. The rubber doesn't actually make a seal, there is a band of adhesive (urethane) that "glues" the w/s to the metal frame. That inside piece of rubber is cosmetic only. You may have a w/s that was replaced poorly and the torrential rain just exposed its weak points.
Get a good caulk gun (21:1 compression or better if you can), and buy a tube of w/s urethane. Cut the tip about 1/8 in down from the top at a 45 angle. Pump the urethane between the rubber and glass from the inside. Start and finish about 6" on either side of problem area and use a popsicle stick to paddle the extra down in there. Don't try to clean up excess until it dries or you will just make a big mess. Any squeeze through can be trimmed off with a razor blade in about 12 hours.
Originally Posted by Mymmars
when your start to anthropomorphise your jeep into somthing above a dog and below a hooker
ziebartrob is offline
post #3 of 4 Old 04-04-2013, 01:10 PM
XJ93
Most auto places should have a product called Flowable Glass Sealer. It's a Permatex product and will flow into the tiny areas no matter the temperature (tried and true), and seal up the leaks. I have used it on many vehicles without fail or issue.
XJ93 is offline
post #4 of 4 Old 04-04-2013, 01:44 PM Thread Starter
kjg26
kjg26's Avatar
Awesome. Thanks yall
kjg26 is offline
