Weird Weird Electrical Problem - JeepForum.com
post #1 of 3 Old 07-16-2007, 06:18 PM Thread Starter
garr79
Hello All,
I have an 89 YJ. For some reason when I step on the brake, the hazards will turn on, they will not blink but be solid. The turn signal do not work either. The brake lights do work though as well as the headlights, dash lights, back up lights.
I am assuming it is a ground but have no idea where else to look. I have looked under the dash a million times, checked all the fuses and still nothing.
There is one plug under the dash with two wires, (orange w/ black stripe, and a solid black wire) It is not plugged into anything but I cant find out where it plugs into.
garr79 is offline
post #2 of 3 Old 07-16-2007, 06:37 PM
laybackman
Bikini Bridge Inspector
laybackman's Avatar
2010 JK Wrangler
Originally Posted by garr79
Hello All,
Maybe you need a new turn signal flasher and hazard flasher relays.
laybackman is offline
post #3 of 3 Old 07-16-2007, 07:30 PM
Jeeples
Jeeples's Avatar
Had a similar problem, as it turned out I accidentally swapped the brake light bulb and reverse lamp bulbs in their sockets.
His: '00 WJ 4.7 Limited- Some stuff
Hers: '03 WJ 4.7 Laredo- Some more stuff
Originally Posted by wjjeep19 View Post
It is what Jeeples has *PARTIALLY* stated.
Jeeples is offline
weird electrical problem zoid TJ Wrangler Technical Forum 5 01-06-2009 11:18 AM
Weird Electrical Problem Buppa YJ Wrangler Technical Forum 11 11-23-2008 12:38 PM
Weird Electrical problem? jloehle TJ Wrangler Technical Forum 4 02-26-2008 10:34 AM
Weird electrical problem ChuckMcDonald TJ Wrangler Technical Forum 7 05-02-2005 01:13 PM
Weird electrical problem... charliezulu TJ Wrangler Technical Forum 1 02-25-2005 05:00 PM
