Weird transmission sounds help! - JeepForum.com
post #1 of 6 Old 10-28-2013, 09:29 PM Thread Starter
Bighaydn
Ive a 94 wrangler that's lifted quite a bit with 35s and 4.10 gears. I've got the 4.0 liter also. So I went and found some mud awhile back. It wasn't too rough and I took it easy on my jeep because I just bought it. After mudding I noticed an odd sound kinda sounded like that sound reverse makes but it happened when I was driving and all gears accept first. I figured some water got in my differential fluid so I changed the front and rear and it cut down but still there. Next I changed my tranny oil and still it's still there! I'm all out if ideas please help! Oh and this is my first jeep and I'm only 20. I'm not an expert
Bighaydn is offline
post #2 of 6 Old 10-28-2013, 10:14 PM
jokerchief462
Did you get ALL the mud and small rocks cleaned out of everything that moves when driving????
The front drive shafts, brakes. Up on the t-case skid where the shafts rotate???
And then the rear the same.
Sent from underneath my Jeep
89YJ 2.5L TBI, AX-5, NP231 SYE, Ford 8.8, Yukon Grizzly, Tom Woods Shaft, 33" BFG T/As, 4" lift, Warn VR10000s.
AF Jeep Club Tail #184
jokerchief462 is offline
post #3 of 6 Old 10-28-2013, 11:15 PM Thread Starter
Bighaydn
I got some but I didn't even think about that. Could something just be rubbing on my drive line?
Bighaydn is offline
post #4 of 6 Old 10-29-2013, 03:36 PM Thread Starter
Bighaydn
That doesn't make much sense though because it's only when I'm on the gas and not when down shifting or coasting
Bighaydn is offline
post #5 of 6 Old 10-29-2013, 09:39 PM
trboxman
1987 YJ Wrangler
Could be u-joints or a loose pinion nut...
Do you have a CV joint rear driveshaft?
The ultimate result of shielding men from the effects of folly is to fill the world with fools.
- Herbert Spencer
trboxman is offline
post #6 of 6 Old 10-29-2013, 09:54 PM Thread Starter
Bighaydn
I'm not sure what that means I just bought it I'm assuming it has stock
Bighaydn is offline
