WEIRD electrical issue!!! - Page 2 - JeepForum.com
post #16 of 24 Old 05-03-2010, 08:40 PM
dodger889
Here is something to try. When it will not start turn the key on. Make sure it's in neutral!!! Jump the starter at solenoid (the starter's heavy( battery ) wire and the small wire) see if it will turn over. If it does the problem is between the switch and the starter. Now if does not start then I would look at replacing the starter.
A 89 yj with a 4.0 aw4 sye out of an 92xj. Now the hard part is done time to get it up in the air just a bit. Working on 8.8 with 3.73 and lsd for the rear. and new D30 hp with 3.73 .
For those who have not figured this out I'm old school but can handle the new too.
Originally Posted by bigsquat View Post
im just cheap, and cheap makes you creative.
dodger889 is offline
post #17 of 24 Old 05-03-2010, 08:51 PM Thread Starter
sprowley
Went to O'Reilly today, got a new starter (more powerful and lifetime warranty for $70), took 20 minutes to put it in and voila! starts every time (so far).
New starter came with a new solenoid as well so I guess we'll never know which one was the culprit... or care really >.>
92 YJ Islander Sold!
97 TJ Sport black on black with MT/R Kevlars and lots of new parts coming!
Canon EOS-1D Mark III, Canon EF 70-200mm f/2.8L USM, Canon EF 17-35/2.8L USM, Sigma 50mm f/2.8 EX USM
sprowley is offline
post #18 of 24 Old 05-03-2010, 08:52 PM
Que89YJ
x2 with Dodger. If the starter isnt turning over make sure your not in gear and try and jump the stater solinoid. It narrows it down. I guess the other question is when it doesnt start listen to hear if your fuel pump is coming on when you try and start and if you see the Check engine light. I know its not the clasic symptoms of the bad caps or crank but it does tell you where your ignition feed is going.
Que89YJ is offline
post #19 of 24 Old 05-04-2010, 10:14 AM Thread Starter
sprowley
UPDATE
Replaced the starter last night. Started 3 times, went to bed. This morning, same issue - no start. So I connected both terminals on the solenoid and BAM - starts right up.
What is left that could cause intermittent issues like this? I know it's not the starter or solenoid, not the power connection between the battery and starter... very likely not a bad ground (not likely to be intermittent)... so what should I check next?
sprowley is offline
post #20 of 24 Old 05-04-2010, 10:34 AM
dodger889
Check your ignition switch. Sound like where all your problem is.
post #21 of 24 Old 05-04-2010, 12:41 PM
Que89YJ
Check you starter relay on the firewall underneath the battery tray and see if your ignition feed is getting there. If you have the ignition feed at the relay then its either a fuseable link or a bad relay. If its good then the ignition switch is bad.
Que89YJ is offline
post #22 of 24 Old 05-04-2010, 02:00 PM
idaholtby
Originally Posted by Que89YJ View Post
Check you starter relay on the firewall underneath the battery tray and see if your ignition feed is getting there. If you have the ignition feed at the relay then its either a fusible link or a bad relay. If its good then the ignition switch is bad.
Good advice except the O.P. has a '92, therefor he has no fusible links and the starter relay is located in the PDC in front of the battery. Could be a bad cable from battery to the starter (internally corroded), a bad ignition switch as previously suggested, or the starter relay and or it's contacts that the relay terminals plug into could be corroded.
idaholtby is offline
post #23 of 24 Old 05-04-2010, 04:53 PM Thread Starter
sprowley
It was the ignition switch. Swapped it out today and haven't had an issue yet, so w00t!
I bought new battery cables too, but haven't installed them yet since no one likes confounding variables. I'll give it a couple of days to make sure the intermittent issue no longer happens, then I'll install the cables.
I'm using my old starter now too. I know I know, at 170k it isn't a bad thing to have a new starter anyway. BUT my old starter works like its brand new and this saved me about $100. That's a lot of money to spend on a replacement part that doesn't need to be replaced!
sprowley is offline
post #24 of 24 Old 05-04-2010, 04:57 PM
idaholtby
Congrats! Hope this fix has legs
electric , electrical , starter , volt , voltmeter
weird electrical issue. NEED HELP ASAP! lexinator02 YJ Wrangler Technical Forum 8 01-05-2010 08:18 AM
well that was weird???? Electrical bug Beltfed09 JK Wrangler Technical Forum 9 12-17-2009 06:12 AM
Weird Weird Electrical Problem garr79 YJ Wrangler Technical Forum 2 07-16-2007 07:30 PM
weird electrical problem jeepin man99 TJ Wrangler Technical Forum 3 07-04-2006 08:40 PM
Weird electrical problem ChuckMcDonald TJ Wrangler Technical Forum 7 05-02-2005 01:13 PM
