Weird! Complete loss of power while driving - Page 2 - JeepForum.com
post #16 of 22 Old 12-08-2004, 11:37 AM Thread Starter
trotter
from trotter: one more clue
i forgot to mention this when i started the thread. maybe it will jog somebody's memory for better problem analysis. after the engine dies and you move to the side of the road - the ignition key is still in the 'on' position. If you try to turn the key from that position and start the engine you get nothing. No engine turn over, no cranking. BUT - if you turn the key back to the 'insert' position and turn the key forward to crank the engine ( as you normally would ) the engine cranks back up fine. That's one reason I initially suspected an ignition system problem. Any more thoughts? Again thanks for all of the feedback - this is a big help.
trotter is offline
post #17 of 22 Old 12-09-2004, 02:12 PM
PhoenixEML
I can sympathize. I have the same damn problem with my 88 I6. I initially thought it was an idling problem because it would happen when I was stopped at a light. Now, it happens all the time, even when I'm giving it the gas. Today it happenned three ******* times. First, when I was going around a corner at a light. It dies every day there, so I was expecting that. The first time that happenned my arms ached for hours after trying to get it to the side of the road. It also happenned at an intersection today (so much fun!) and then on the way home. I find that if I put the car in park, turn the key back and then try again, I can usually get it started.
My mechanic was convinced it was the carb (and it's been replaced twice in the last month) and the last time when a hole in my float was found, we thought the problem was set. All this power loss is leading me back to an ignition problem. So, it's going to a new mechanic tomorrow morning. Sorry I can't be more help, but I definitely feel your pain.
PhoenixEML is offline
post #18 of 22 Old 12-10-2004, 03:46 AM
BamaJeeper
BamaJeeper's Avatar
If you wiggle the key when it's running does it shut off?
Out of the darkness comes light.
BamaJeeper is offline
post #19 of 22 Old 02-02-2010, 10:54 PM
embrabander
hey did you end up figuring it out, i got an 89 that started doing the same thing, its got the 4.2l motor in it and just started acting up the other day
embrabander is offline
post #20 of 22 Old 09-25-2011, 07:58 AM
Jvandy1252
Same type problem
Jumping on the boat. Same type of problem with 94 yj 4cyl. Bought for my son to drive to school. Initial problem was blowing fuel fuse. Replaced with a circuit breaker and ran fine until we discovered a short in the ground to the battery. Fixed that problem. Starts and runs anywhere from 10-30 miles, then just dies. If we let it cool down, starts and runs again 5-30 miles. New to the Jeep thing, but frustrated. Where should I start? Is it possible for a fuel pump to "overheat" ? Seems it could be heat related. I've heard about the ECU, but havent researched it much. Initial problem was blowing fuel fuse, thought about rewire fuel pump, and then replacing fuel pump. Not sure thats where I should be starting. From reading here, maybe (in order): ICM, Crank position sensor, coil???? Help Please!!
Jvandy1252 is offline
post #21 of 22 Old 10-19-2011, 03:13 AM
BigRed7
This seems to be a more and more common problem. I've seen several threads about this very issue, including my own. I've put in a new ignition control module, coil, fuel pump...also a new carb and exhaust system besides the problem. I even did the Nutter Bypass...still has the problem. I've just replaced the Solenoid, called the ignition relay on some schematics and parts break downs. I think who ever figures it out should get an award! I have not been able to duplicate the problem unless it's being driven, gets scary when it happens while driving and is not safe though. I've also been looking towards the fusible links that come off the Solenoid.
BigRed7 is offline
post #22 of 22 Old 10-24-2011, 05:06 AM
Jvandy1252
Possible "Cure" - Worked for me!
So far so good . From another thread on this forum, they suggested I replace the Crank Position Sensor. I replaced the o2 sensor and crank position sensor at the same time. ( About a 20 minute fix). My son has driven at least 4 hour and a half trips back and forth so far and no problems!! Believe the Crank position sensor was about $60 o2 sensor about $35-40.
Exhaust noise, Complete loss of power after accident smithtime09 TJ Wrangler Technical Forum 6 08-22-2009 07:12 PM
Complete loss of juice md41969 YJ Wrangler Technical Forum 6 09-24-2007 01:21 PM
Help, total loss of electrical power while driving? iflycoptors TJ Wrangler Technical Forum 19 07-28-2007 08:25 AM
Complete Power Loss at Highway Speeds tmwoodall TJ Wrangler Technical Forum 8 02-20-2007 01:44 PM
Weird Loss of Power Feeling BRad704 YJ Wrangler Technical Forum 4 05-11-2005 08:16 AM
