Weird! Complete loss of power while driving - JeepForum.com
post #1 of 22 Old 12-03-2004, 08:45 PM Thread Starter
trotter
Recently I have been driving my 1993 4-cyl and have a complete loss of power. Have to wrestle it over to the side of the road, no power steering, brakes, etc. Engine cranks back up and I go again. Sometimes it happens several times every 2-3 minutes. First started occasionally and now occurs with great frequency. I'm afraid to head out anywhere any more. I suspect an ignition system problem, but don't know. Think it could be the PCM ? Anybody else experience this weird thing or got any ideas ??
trotter is offline
post #2 of 22 Old 12-03-2004, 09:45 PM
flxpain
The dealer is going to tell you it is the computer. but let's get this thing back up on the top and see if there are more ideas.
FLXPAIN-it's what I got
Green Jeep Club Member #135
Current Jeep-
95' YJ Rio Grande 3.5 Rough Country Lift. 3" body Lift. 31" BFG AT's. 2.5L Soon to have a pair of Sentinals Vent covers!
flxpain is offline
post #3 of 22 Old 12-03-2004, 09:52 PM
CAJUN_YJ
CAJUN_YJ's Avatar
p
It could be as simple as a bad coil or fuel pump.
CAJUN_YJ is offline
post #4 of 22 Old 12-04-2004, 07:51 AM
Richmond88yj
Eat, Sleep, Jeep
Richmond88yj's Avatar
Had same symptoms on mine, turned out it was the ignition module. 20 minutes, 20 bucks from Autozone.
- Ernie
Richmond88yj is offline
post #5 of 22 Old 12-04-2004, 05:46 PM
krasjeep
had same sort of problem w/my '93 soon after purchase... took back to dealer... no answers... checked harness... found broken clip on wire to coil... vibrations would loosen it... trashed coil for Accel Computer Coil... problem solved! Look REAL close at harness, making sure all connections are solid... don't start throwing parts at it 'till you check the small stuff.
I'd rather push a Jeep than drive a Ford!
1993 Jeep Renegade, 2" body, 31/10.50/15's on 15x7
chrome mods, trashcanned sway/track bars, custom rear bumper, hi-lift and HUGE strap!
180,000 miles on motor, 2nd tranny and rearend.
http://home.earthlink.net/~amx4080/rene/images/krasjeep.jpg
2003 Yamaha Warrior (quad)
2003 Yamaha TTR-90 (dirt)
2003 Kaw KFX-90 (quad)
1974 Dodge Ramcharger, 318/727/203, trimmed fenders,
35/12.50/15 Dunlop Mud Rovers, 89,000 orig. mi.
krasjeep is offline
post #6 of 22 Old 12-04-2004, 06:28 PM
mrclean
stall
As was said in previous replies, check all connections first. If all check OK, run your computer codes, the PCM may diagnose the problem for you. You didn't specify if just the engine stopped running or total electrical was lost. If just the engine quit, a Crank Position Sensor on its way out will cause the problem you describe.
mrclean is offline
post #7 of 22 Old 12-04-2004, 07:02 PM
BamaJeeper
BamaJeeper's Avatar
Check the codes before you assUme anything. If you don't know how click below and scroll to the last
post.http://www.jeepforum.com/forum/showthread.php?t=39873
Out of the darkness comes light.
BamaJeeper is offline
post #8 of 22 Old 12-04-2004, 07:30 PM
wherndon
What the hell?
wherndon's Avatar
Mine had a bad coil (twice actually) that did the same thing.
The engine would randomly shut off as I was driving.
One day it finally shut off and would not restart.
________________________________
'05 Rubi, Patriot Blue, RE SF, Antirock, Warn, Fabtech, Tomken
_________________________________
2000 Grand Cherokee Laredo V8, Patriot Blue
Stock
'93 YJ Sport, Canyon Blue
4.0, auto, air, limited slip, HT.
2.5" Rancho suspension, Ramsey 8000
Previous Jeeps...
'91 XJ Laredo, white
'87 YJ Sport, white
wherndon is offline
post #9 of 22 Old 12-04-2004, 09:03 PM
COJAM
COJAM's Avatar
Before you go to the dealer!!!
Go to a goo auto electric shop. They will know more than the dealer!!
GBD
COJAM is offline
post #10 of 22 Old 12-05-2004, 10:37 PM Thread Starter
trotter
Actually the power loss was to the engine and power (such a steering, brakes. etc.) With the engine still turned off you could turn on the lights and they were working. I didn't think to check the radio or fan, etc. Really appreciate all the great replies - big help - these responses at least give me a direction or two. Thanks again - folks.
trotter is offline
post #11 of 22 Old 12-06-2004, 01:19 PM
tntauto
Newbie
Loss of spark
My 1990 4.2L just started doing the same thing. Replaced starter (for other reasons), coil (since it was cheap) and distributor. Still same problem. Runs, then stops after minutes or hours. May not restart. Thinking ignition module. If so, where is it located? Any help would be appreciated. Thanks
tntauto is offline
post #12 of 22 Old 12-06-2004, 04:36 PM
DesertYJ
My 95 did the same thing...it was the O2 sensor going out. When I turned it off it resets and worked fine for a while...becoming more frequent.
DesertYJ
94 YJ Trail Rated
"I love it when she crawls on all 4's"
DesertYJ is offline
post #13 of 22 Old 12-06-2004, 07:39 PM
bidnizman
tntauto...
I had the same exact symptoms as you, luckily I replaced the Ignition Control Module First, and save a lot of money. It is located under the Radiator overflow tank. You have to remove the tank to get at it, two bolts. Then it bolts through your fender well, those bolts are removed from the fender well side, three of them. The module costs around $20, and is actually from a Ford. I know a few Ford guys that keep an extra in their glove compartment. You might have to splice different plugs in, other than that its a twenty minute job.
Any questions, PM me.
'89 Laredo, Rebuilt 4.2L w/4.0 head, Weber carb, Header and Cat-free Flowmaster, Tuffy Stereo Console, 32's..... Love/hate relationship
bidnizman is offline
post #14 of 22 Old 12-07-2004, 03:57 AM
BamaJeeper
BamaJeeper's Avatar
Trotters YJ does not have an ICM.
post #15 of 22 Old 12-07-2004, 09:12 AM
bidnizman
I know Trotters Jeep doesnt have an ICM, that's why i put TNTAUTO in the subject line , to try and eliminate any confusion. But thanks for your help.
Exhaust noise, Complete loss of power after accident smithtime09 TJ Wrangler Technical Forum 6 08-22-2009 07:12 PM
Complete loss of juice md41969 YJ Wrangler Technical Forum 6 09-24-2007 01:21 PM
Help, total loss of electrical power while driving? iflycoptors TJ Wrangler Technical Forum 19 07-28-2007 08:25 AM
Complete Power Loss at Highway Speeds tmwoodall TJ Wrangler Technical Forum 8 02-20-2007 01:44 PM
Weird Loss of Power Feeling BRad704 YJ Wrangler Technical Forum 4 05-11-2005 08:16 AM
