Weird Clicking Noise - JeepForum.com
post #1 of 7 Old 09-16-2011, 10:37 PM Thread Starter
swbfvd
Ok, well when I start my Jeep cold there is a very low clicking noise that clicks like every 7 seconds. Then it go away until I come to a stop in neutral, where it clicks while I roll to a stop. Also when I am in 3rd(20-30mph) gear and let my foot off the pedal there is a quiet clanking sound until I press down on the pedal again. Also I am not that mechanically inclined. If anyone can help me thank you.
swbfvd is offline
post #2 of 7 Old 09-16-2011, 10:43 PM
moonshinefuel
Clicks and clanks..that's an everyday event for me.
AX5/NV3550 Conversion Thread.
Bow Hunting
moonshinefuel is offline
post #3 of 7 Old 09-16-2011, 10:56 PM Thread Starter
swbfvd
Aw man, its kind of annoying, do you have any idea what it could be, I was thinking it could the U-joints but i have not found a good description of how to check for that. Mainly because I'm not that good a mechanical stuff I don't want to ruin or mess anything up
swbfvd is offline
post #4 of 7 Old 09-16-2011, 11:30 PM
tankinyj
its a YJ man, they make plenty of noises. mine makes a weird rubbing/clanking noise when i shift, but im sure thats due to the fact that i jerry rigged my own tranny mount bolt with washers and bushings.
your description is not to clear either. a clicking? a clanking? this could be a number of things. if you could give us a better description then possibly we can help you out. but as of right now your description is far too vague to point out what clicking and clanking sounds you have, cuz we all have plenty of those noises on a regular 24/7 basis
edit: it is 100% not your u-joints. your u-joints would make the noise as you are moving, never if you were stopped.
tankinyj is offline
post #5 of 7 Old 09-17-2011, 06:25 AM
ziebartrob
Try to narrow it down a little more. Like said, prob not your U joints based on your description. It could be just a little lifter noise which mine has had for the last 30k miles, and it runs like a top. Open the hood and try to see if its coming from eng, etc... Have someone ride with you and try to isolate where its coming from. Just need a little more info to help ya out.
Originally Posted by Mymmars
when your start to anthropomorphise your jeep into somthing above a dog and below a hooker
ziebartrob is offline
post #6 of 7 Old 09-17-2011, 06:31 AM
Soldierfoley
^^^this. or a clutch problem. Hopefully this^^^
The Ujoints. You said it clicks in 3rd and when rolling slow "to a stop"
Soldierfoley is offline
post #7 of 7 Old 09-17-2011, 07:46 AM
G30SFF250
Check your U joints.
I would rather have a broke Jeep, than no Jeep at all.
G30SFF250 is offline
Weird clicking noise RyanE5 TJ Wrangler Technical Forum 9 01-20-2012 04:14 PM
Weird Metal Clicking/Ticking/Rattle JeepScrap TJ Wrangler Technical Forum 0 09-09-2011 04:14 PM
clicking noise coming from cluster, weird! help! ozo101 TJ Wrangler Technical Forum 2 11-18-2008 03:09 PM
clicking noise coming from cluster, weird! help! ozo101 TJ Wrangler Technical Forum 1 11-18-2008 02:56 PM
Weird clicking aagongora TJ Wrangler Technical Forum 2 06-10-2004 04:08 PM
