weird 92 YJ idle - JeepForum.com
post #1 of 6 Old 12-01-2006, 07:12 AM Thread Starter
92wrangler
weird 92 YJ idle
Hey guys lately after i installed my new cat i have noticed on start up my jeep has a hard time finding it's idle. It sounds like a cammed car in the beginning and then the RPM's drop really low and then shoot back up and then it finds it's place and stays there. The jeep has never actually quit running but the RPM's seem to get low enough to warrent this eventually. What is causing it to do this. Is there a sensor that could be going bad or something it never did this before.
thanks for any info in advanced
Jason
2001 Grand Cherokee Limited v8 4.7L H.O Black, leather, fully loaded, tinted windows all the way around
1997 camaro Z28 Fully forged 355, Stage 3 heads, Gm847 cam, Nitrous,
92wrangler is offline
post #2 of 6 Old 12-01-2006, 07:29 AM
Why J?
Why J?'s Avatar
I would suspect a bad IAC motor, It is what adjusts the idle, They sometimes get gumed up with Carbon and don't move like they should. If it continous you will start seeing the idle drop when coming to a stop and turning.
New Project "Pissed Wife"
Phase II 5.3L/4L60e then NV3550
Why J? is offline
post #3 of 6 Old 12-01-2006, 07:37 AM Thread Starter
92wrangler
How much are these can i take it off and clean the carbon out of it with say a throttle body type spray cleaner? Thanks
Jason
post #4 of 6 Old 12-01-2006, 07:40 AM
Why J?
Why J?'s Avatar
Around 45.00, or so. You can try to clean it out, but it never helped for me.
Why J? is offline
post #5 of 6 Old 12-01-2006, 07:46 AM Thread Starter
92wrangler
ok thanks for the info i'll probably just end up buying a new one. It might be easier in the long run then doing it more then once. Where are they located? I just put a new motor in my jeep and did not notice seeing it anywhere. I suppose i could go get out my Chiltons manual.
post #6 of 6 Old 12-01-2006, 08:12 AM
Why J?
Why J?'s Avatar
It is located on the throttle body itself.
Why J? is offline
4.0 has weird idle at start up and then goes away 488TJ TJ Wrangler Technical Forum 11 05-11-2009 04:36 PM
weird idle bcridez TJ Wrangler Technical Forum 3 10-03-2004 09:08 PM
Weird Idle 1994Wrangler YJ Wrangler Technical Forum 1 12-28-2003 09:04 PM
weird idle Meister_jeep YJ Wrangler Technical Forum 6 12-16-2002 10:00 AM
Low/weird idle on 95 YJ 2.5L goofus YJ Wrangler Technical Forum 2 09-25-2002 10:53 AM
