This is weird? - JeepForum.com
post #1 of 2 Old 07-17-2001, 03:40 AM Thread Starter
bigjeep39
bigjeep39's Avatar
This is weird?
Ok, small problem! I wrote a while about a fuel pump and fuel system errors, well right when i thought it was fixed it broke again, i installed an electric fuel pumpto try to fix problems, my Jeep had a miss in the idle somewhere along 1,000 - 2,000 rpm, it is like a popping noise followed by no power. It did that right in an intersection and died, well what can it be, there is no fuel getting pumped even when i turn on the electrical pump, so i poured fuel in the floatbowl in the carburator and then the pump pumped a little air then fuel, is it a leak somewhere or a carb problem, there is also a gaping hole in my exhaust- It is an 1989 YJ 258 6cyl 4.2 litre, Cali. emissions even though i live in New Mexico, and it has 175,000 miles Please Give Some Input
1998 TJ
Slow steady project.
bigjeep39 is offline
post #2 of 2 Old 07-17-2001, 08:24 PM Thread Starter
bigjeep39
bigjeep39's Avatar
the linkage??
I will try the cleaner and maybe service the carb, or buy a weber or holley 2 barrel!
1998 TJ
Ok this is a weird one choeyreplied TJ Wrangler Technical Forum 4 03-02-2009 09:48 AM
Weird Weird Electrical Problem garr79 YJ Wrangler Technical Forum 2 07-16-2007 07:30 PM
Weird Problem... Weird fix... 1BadJeepX06 TJ Wrangler Technical Forum 4 01-08-2007 07:59 AM
How weird would this look...? ScottioTJ TJ Wrangler Technical Forum 25 01-30-2005 01:17 PM
