Webers & vacuum hoses PLEASE HELP - JeepForum.com
post #1 of 2 Old 12-02-2001, 08:04 AM Thread Starter
Brendan
I have finally got the money to buy the weber for my 88. The only thing that is holding me back is the vacuum hose situation. How will I know what to connect, and what to throw away. I am all for simplification of the engine, but at what cost to my emissions? Please help me. Everyone seems to have the same answer to this question. "Webers will fix your problems" ANY input would be highly appreciated. Thanks
Duvie
95 YJ 2.5L 5 Speed
Fightin a war against Florida Rust!
Brendan is offline
post #2 of 2 Old 12-02-2001, 08:20 AM
glm 87 wrangler
Hey i have an 87 4.2 with the weber and the hoses on your air cleaner are gone the only
ones i use are the Vac advance from the distributor and the gas vent on top of the carb to the purg canaster The other will go to the back pvc valve to the weber air cleaner hope this helps.It should come with the directions.If you have not got it yet try
topendperformance.com or just punch in keyword weber they should come up they were
one of the cheaper ones.Four wheel drive hardware were too high.Hopr this helps if you have any probs drop me a email.shockerforme@aol.com
Gary 87 Wrangler 4.2 258 with weber carb and TFI upgrade.
31/10.5 and Nutter bypass!
glm 87 wrangler is offline
4x4 vacuum hoses WarlockLord YJ Wrangler Technical Forum 1 04-28-2005 04:55 PM
4WD vacuum hoses JPH YJ Wrangler Technical Forum 3 02-24-2005 03:26 PM
4X4 Vacuum Hoses! cypher740 YJ Wrangler Technical Forum 1 11-02-2003 03:46 PM
Vacuum hoses, help! Mark TJ-YJ YJ Wrangler Technical Forum 6 01-13-2003 12:14 AM
Vacuum Hoses 90 YJ 4.2L muddymark YJ Wrangler Technical Forum 1 09-16-2001 11:30 PM
