Weber WEBWK551-36S base settings? - JeepForum.com
post #1 of 5 Old 07-12-2009, 11:39 AM Thread Starter
mark12010
I have a weber WEBWK551-36S and when I try to adjust it I can turn in the air fuel mix screws with no effect what so ever. I have tried so much I cannot seem to get it back to normal. Can someone tell me what the base settings are for the air fuel mix screws , the fast idle and idle speed screws. I want to start from where they were when it first came out of the box.
mark12010 is offline
post #2 of 5 Old 07-12-2009, 06:21 PM Thread Starter
mark12010
Nobody knows the settings????
post #3 of 5 Old 07-12-2009, 09:56 PM
Felonious_monk
What do the instructions say?
88YJ
53CJ-3B
Felonious_monk is offline
post #4 of 5 Old 07-13-2009, 05:12 AM Thread Starter
mark12010
The Instructions just go over how to make adjustments NOT what the carb is set at out of the box. As stated in my post. I have made so many adjust ments I feel as if I need to go back to square one. In order to do this I need to get the carb back to the "out of the box" settings.
post #5 of 5 Old 07-13-2009, 08:03 AM
Felonious_monk
Which is written clearly in the directions.
I don't know what the baseline settings are for the carb you have, but they are usually something like.....
Idle speed screw set at 1/2-3/4 turns in after contact.
Mixture screw set at 3/4-1 turns out after bottoming it out.
88YJ
53CJ-3B
some weber questions for weber users giggityjeeper YJ Wrangler Technical Forum 12 06-09-2010 09:24 PM
Weber 34 DGEC Versus the Weber 32/36 DGEV FrankieCarbone YJ Wrangler Technical Forum 24 03-06-2010 09:33 AM
Heater Not on settings 1 and 2 armartel TJ Wrangler Technical Forum 1 08-06-2008 10:04 PM
settings, help..... kbradner83 YJ Wrangler Technical Forum 5 11-01-2007 10:41 AM
Rancho Steering Dampener Torque Settings vs FSM Settings wrangler2002 TJ Wrangler Technical Forum 5 11-28-2005 03:32 PM
