weber vent to ground! - JeepForum.com
post #1 of 2 Old 09-04-2011, 04:00 PM Thread Starter
boardmaker
I just installed a weber 32/36 to replace the original carter bbd. I installed the vent tube as instructed and noticed that it simply dead-ended to the ground! I am no mechanic but I know that ain't right. I assume this should go to a vapor canister? What should I do in the absence of said canister.
boardmaker is offline
post #2 of 2 Old 09-04-2011, 04:06 PM
mcmud
1983 CJ8
Plug or cap the bowl vent nipple at the carb.
mcmud is offline
some weber questions for weber users giggityjeeper YJ Wrangler Technical Forum 12 06-09-2010 10:24 PM
stock height front bumper to ground and rear to ground asjeep TJ Wrangler Technical Forum 9 04-12-2010 02:36 PM
Weber 34 DGEC Versus the Weber 32/36 DGEV FrankieCarbone YJ Wrangler Technical Forum 24 03-06-2010 10:33 AM
AC/Heat vs. Vent (( vent dosen't work idk why )) gamer0 YJ Wrangler Technical Forum 10 04-10-2009 11:24 AM
To Weber or Not To Weber, THAT is the question. Delta347 YJ Wrangler Technical Forum 4 01-17-2009 07:29 PM
