Weber or motorcraft? - JeepForum.com
post #1 of 19 Old 08-01-2013, 02:38 PM Thread Starter
Chase0808
I need to switch from my EMPI carb. Not sure what to get yet. I have a 88 yj an I hear to get either a weber or a motorcraft. Not sure which one or which model I want.
Chase0808 is offline
post #2 of 19 Old 08-01-2013, 03:20 PM
rambo3489
Get the motorcraft. You won't regret it. Simple, great design, easy to rebuild, just really solid. I have heard the webers take a little more effort to keep running well. But at the same time are also a good choice.
Sent from my phone because I'm doing something "more important"
89 YJ.. My first jeep and I won't let it go. ▀||||▀
Current Project: None... I disgust myself.
<a href="
THE YJ MY WAY</a>
rambo3489 is offline
post #3 of 19 Old 08-01-2013, 03:28 PM Thread Starter
Chase0808
What model? I know there is a 2100 and a 2150 but I'm not sure which on to get.
post #4 of 19 Old 08-01-2013, 03:56 PM
roadyrob
1987 YJ Wrangler
replaced my empi carb with a holley, luv it. of the 2 you posted I'd go with motorcraft.
Do everything with a positive attitude, it won't always work but you'll piss enough people off to make it worthwhile.
the voices aren't real but they sure have good ideas.
roadyrob is offline
post #5 of 19 Old 08-01-2013, 04:04 PM
rambo3489
Id vote for the 2150. It's a little more sophisticated it has an altitude compensating valve. So when you go to higher elevations it leans it out some.
They are basically identical other than that.
I had an old abused 2100 on mine. Rebuilt it a while ago. It started giving me problems recently. So I went to rebuild it again. (probably didn't have to) Anyways broke my venturi. So I bought a new 2150 from the ebay guy. It has been amazing. But it is also brand new.
Don't know your mechanical abilities. But if you are not really into tinkering and rebuilding a carb. Look into a new one from the ebay guy. ehrmannmp is his name. He gives you good easy to follow directions.
<a href="
THE YJ MY WAY</a>
post #6 of 19 Old 08-01-2013, 04:18 PM
rocketboy
rocketboy's Avatar
Just pulled my Weber and replaced it with the 2150. Night and day. Get the Motorcraft from the ebay guy.
rocketboy is online now
post #7 of 19 Old 08-01-2013, 04:22 PM
rambo3489
REALLY? Most people I have heard say they are all around similar. What was your Weber experience?
<a href="
THE YJ MY WAY</a>
post #8 of 19 Old 08-01-2013, 04:41 PM
rocketboy
rocketboy's Avatar
First of all, there are Webers and there are knock-off Webers. I got a knock-off evidently. If you go the Weber route buy it from Redline Weber, not Weber Carbs Direct. Redline sells the real ones.
That being said, I bought from Weber Carbs Direct and to be honest, it ran well. However, no matter how I changed out jets and ran the best lean idle procedure, it always was a bit rich.
I never passed emissions. Last year I found someone to pass it but this year it failed again.
I replaced it with the motorcraft last weekend. It passed with flying colors! And the power and response is so much better. And, while I've only used a half a tank of gas so far, my mileage seems better.
So maybe my problems all stemmed from not having a "real" Weber. But even if the real Weber is better, I can't see it being better than the 2150.
Price is comparable ( I think the MC is a bit more) and the MC is much easier to tune and work on.
Others can speak up, but my advice is to buy the Motorcraft.
___________________
1989 YJ - 4.0L
2001 WJ 4.0L
post #9 of 19 Old 08-01-2013, 05:45 PM Thread Starter
Chase0808
It seems like they're both good but I'm going to go with the motorcraft 2150. Anyone know if its a pain to install myself?
post #10 of 19 Old 08-01-2013, 06:06 PM
rambo3489
The carb install is pretty simple. The Nutter bypass can be a little tricky. If your new to things. But it's well documented and isn't bad either.
I would do both if your getting a new carb. You will be amazed with the power increase.
<a href="
THE YJ MY WAY</a>
post #11 of 19 Old 08-01-2013, 06:22 PM Thread Starter
Chase0808
I did a carb change a while back but never a motorcraft. I should be able to, I do most the stuff like lift and stuff like that.
post #12 of 19 Old 08-01-2013, 08:06 PM
rocketboy
rocketboy's Avatar
If you've done a carb R&R before, the motorcraft won't be anything different.
The most complicated part is removing all the crap you no longer need and retorting the vacuum lines. But the eBay guy on Colorado provides pretty good instructions. And we're here to help you if you need us👍
___________________
1989 YJ - 4.0L
2001 WJ 4.0L
post #13 of 19 Old 08-01-2013, 08:08 PM
rocketboy
rocketboy's Avatar
Re routing that is.
___________________
1989 YJ - 4.0L
2001 WJ 4.0L
post #14 of 19 Old 08-01-2013, 08:17 PM Thread Starter
Chase0808
Okay. I'm buying the 2150 off of the guy in Colorado on eBay. Is there anything else that I'll need? Like an air filter?
post #15 of 19 Old 08-01-2013, 08:32 PM
rocketboy
rocketboy's Avatar
I purchased an air filter and electric choke from him with the carb. They're extra. If you have a carter with the electric choke, I believe you can swap it out. I just bought it with the electric choke because it was like $20 and I didn't feel like messing with it. His eBay listing will have all the details.
___________________
1989 YJ - 4.0L
2001 WJ 4.0L
