Weber Issues - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > YJ Wrangler Technical Forum > Weber Issues
ROCK BOTTOM prices on LIFT KITS at Rockridge4wd!! WANT TO Alloy usa heavy duty ball joint kitsWe have FLASHLIGHTS! Great for your Emergency bag!
Unread 05-12-2014, 01:43 PM   #1
encorick
1987 YJ Wrangler
Weber Issues
Hi all -
I started one of those 'sweater thread' type projects on the jeep... everything I touched unraveled, creating more of an issue. Prev post was here where I started troubleshooting some rough running issues at highway speeds: http://www.jeepforum.com/forum/f12/c...97/index2.html
Thinking this is more of a carb issue now - so starting a new thread.
1987 YJ w 4.2, auto tranny, weber carb, misc other PO mods.
In attempting to replace a single outlet clear fuel filter with a stock type filter w bypass, the engine won't run if bypass is open.
Also, when watching fuel flow from bypass when cranking the engine over, its constantly bubbling air out.
I purchased a rebuild kit for carb (expecting it in early this week) as I don't believe anything has been done on this vehicle in a very long time.
Where is air in bypass line coming from? Is carb so jacked up that its pulling air back into fuel stream? Will a rebuild address that?
encorick is offline   Reply With Quote Quick reply to this message
Unread 05-19-2014, 11:40 AM   #2
encorick
1987 YJ Wrangler
rebuilt the weber, vehicle still won't run with bypass connected.
Purchased a Mr Gasket fuel pressure regulator and installed downstream of filter.
With bypass open, there is no measurable fuel pressure. Pinching off bypass I am able to get consistent fuel pressure across idle to higher revving RPM's.
After vise grips are released on bypass, vehicle will stumble then die, as fuel pressure drops to nothing.
Planning on removing standard filter with a bypass, and going back to one without a bypass, and using the fuel pressure regulator to limit pressure to carb. Will this create any issues with either the fuel pump, lines, filter, etc? I'm not familiar with the internal plumbing of the mech pumps - will the backpressure by not having a bypass cause premature failure, potential leaks, fire, flood, famine??
Unread 05-19-2014, 11:45 AM   #3
superj
1987 YJ Wrangler
which weber carb is it?
if its a 34/34, throw it away and get something else. i love weber carbs and had to take that junk off mine when i got. nothing but problems. its not a real weber carb.
you have the bypass line on the filter on top? will give trouble if its on the bottom and the carb feed is on top
Slow ride, take it easy
superj is offline   Reply With Quote Quick reply to this message
Unread 05-19-2014, 11:46 AM   #4
rocketboy
rocketboy's Avatar
Maybe you just got a bad filter. It happens. They're pretty inexpensive so you might want to put another on and see if that helps.
I replaced my stock fuel filter when I replaced my carburetor and experienced cutting out at highway speeds. Kept checking all kinds of things on the carb and couldn't fix it. I ended up replacing the fuel filter again and it solved my problem.
rocketboy is offline   Reply With Quote Quick reply to this message
Unread 05-19-2014, 12:05 PM   #5
rocketboy
rocketboy's Avatar
Also, the filter is supposed to be oriented so the small line is on the top. My understanding is that it won't work properly if it's not oriented that way.
Unread 05-19-2014, 03:47 PM   #6
encorick
1987 YJ Wrangler
yep - filter oriented horizontally with smaller (bypass) line on top.
Carb is a 32/36 DGEV.
Behavior has been consistent across a couple of different filters. Tried one each from NAPA and Advanced.
From reading this afternoon it sounds as if theres a couple schools of thought with the mech pumps - with a bypass, a fuel pressure regulator shouldn't be needed, and if you use one, a bypass isn't needed, so I'm going to go with option 2, cap off bypass line at the transition to the hard line, revert back to the single output style filter and move on to my next project... leaky front axle seals and diff cover. Anxious as to what fun I'll find in there, as everything else on this vehicle has not been maintained!
Unread 05-19-2014, 04:10 PM   #7
shovelrunner
1987 YJ Wrangler
If it helps I do not use a regulator on my 87 with a 4.2, same carb. I know a lot of people say don't trust the mechanical pump, but I must have gotten lucky cause my pressure is constant and since a really good tune up was done it rubs like a champ! Good luck.
shovelrunner is offline   Reply With Quote Quick reply to this message
