Weber Idling Issues - JeepForum.com
post #1 of 3 Old 01-20-2005, 11:28 AM Thread Starter
hguffman
hguffman's Avatar
Weber Idling Issues
Well, my electric fan failed on my jeep while I was warming it up the other day. The circut never closed when it got to temp and it puked out all the coolant in my engine and radiator while I was inside flapping my f-ing gums . It had pinned the temp needle, but after all that, I replaced the fluid, let it cool and it got me home fine... no cracks in the block or any thing.
After replacing the radiator, doing the tune up and replacing a few ignition components the damn thing still won't idle and the choke doesn't seem to be working properly.
The idle will fluctuate between 1500 and as low as 500 and when coming to a stop it dies or alomost dies when I press the breaks... any thoughts as to what I coudl check? Could I have heated things so much in teh carb that I burnt out some vital components? Its a Weber that is less then one year old, and before this miss hap it ran GREAT!... so whats next?
Brian
89 Wrangler 4.2L w/ Posi-Lok, Weber Carb, Electric Cooling Fan
THE RED SOX WIN THE PENNANT!!! THE RED SOX WIN THE PENNANT!!!!
THE RED SOX WIN IT ALL!!!!!! WORLD CHAMPIONS BABY!!!!
hguffman is offline
post #2 of 3 Old 01-20-2005, 11:56 AM
jeepnguns
jeepnguns's Avatar
I would warm up the vehicle to normal operating temperatures and unplug the electric choke and make sure it is in the unengauged position. if this solves the problem you most likely got the choke wet and just need to replace it. Second thing it could be is the ignition module since the coolant overflowed probably from the overflow tank the ignition module might have gotten wet and is shorting out. Unfortunatly I do not know how to test them if there is a test. third thing is there might have bee some internal engine damage. good luck.
88 Wrangler
350 Chevy engine vortec heads Holley Pro-Jection
Ford T-18 Tranny
Dana 44s Detroits w/ 5.89s
38" Swamper SX
Lots of other random things and dents
jeepnguns is offline
post #3 of 3 Old 01-20-2005, 12:03 PM Thread Starter
hguffman
hguffman's Avatar
Yeah, I did replace the ignition module. that helped.
i will see about the choke tonight.
Brian
hguffman is offline
Idling issues after dead battery Iamjr TJ Wrangler Technical Forum 2 01-25-2010 10:20 AM
Weber Conversion Issues Boris61 YJ Wrangler Technical Forum 8 10-09-2009 06:31 PM
4.0 idling issues WVjeep94 YJ Wrangler Technical Forum 13 01-23-2009 02:09 PM
Timing Issues with Weber 32/36 autocustomz YJ Wrangler Technical Forum 3 11-15-2007 07:53 PM
Idling issues jsandmel YJ Wrangler Technical Forum 3 10-07-2004 03:47 PM
