weber float question - JeepForum.com
post #1 of 4 Old 05-18-2012, 12:26 PM Thread Starter
bluedaffy
I was trying to narrow down the causes of my idle going from smooth to lopey over time after coming to a stop. Here's how it goes:
Driving= fine
Idle after stopping= fine
Idle 30-60 seconds after stopping= loping
When I get out and take the air cleaner off the carb (weber 32/36) there is usually gas where the arrow is pointing. Is this normal? What does this mean?
bluedaffy is offline
post #2 of 4 Old 05-18-2012, 02:16 PM Thread Starter
bluedaffy
bump... just so someone might actually view this thread. lol.
post #3 of 4 Old 05-18-2012, 07:41 PM
patde
1987 YJ Wrangler
check your fuel filter position the re tern should be on top mine was just a hair off and it did that, after that you can check the float inside that may be off a bit weber.com has all the specks on it. one other thing do you have a fuel pressure reg... i think the weber runs at 3-5 psi stock fuel pump is way to much for it
patde is offline
post #4 of 4 Old 05-18-2012, 07:45 PM
superj
and you should have fuel in those slots. hose two brass things in the one slot are your jets and they need to be under the fuel or you definitely have a float level problem
I don't feel like working on anything at this time so i sold my yj.
superj is offline
idle , weber
weber DGEC/DGEV float specs Scurv YJ Wrangler Technical Forum 1 10-14-2009 07:41 AM
no gas in float bowl weber CostaRicaJeep YJ Wrangler Technical Forum 2 12-30-2008 02:37 PM
Fule pump/float harness question bigredcherokee YJ Wrangler Technical Forum 1 07-20-2008 11:39 PM
Weber Float Level RabiDaWise YJ Wrangler Technical Forum 0 11-13-2006 01:09 PM
Weber float adjustment johny1i YJ Wrangler Technical Forum 0 07-03-2003 12:30 PM
