weber carb swap - JeepForum.com
post #1 of 2 Old 04-27-2010, 06:04 PM Thread Starter
solo29
weber carb swap
hello everyone i have a question i swaped from the pos carter to a weber man what a differents it has made better gas miliage also did the nutter but i had someone put carb on but the eletric choke dosent work do any of yall know where it needs to connected at right now its not connected at i live in florida so for now it hasent been a big problem yet?
solo29 is offline
post #2 of 2 Old 04-27-2010, 06:11 PM
monkeyhouse
there's not even close to enough information there to allow me to help you. Fill out your profile with everything you know. In the meantime...
The weber should use the same power source as the carter did, mine did, but I have no idea what year jeep you have or what engine. Was your carter an electric choke?
First Jeep was an 1989 YJ, 6 cylinder 4.2L , 258. Nuttered and TeamRushed, Weber 38 DGES, Now, I'm venturing into the world of Grand Cherokees
monkeyhouse is offline
Weber Carb vs. Stand. Carb 89 YJ Beast89 YJ Wrangler Technical Forum 10 05-20-2012 10:38 AM
Carb swap, considering a Weber upgrade. all10cylinders YJ Wrangler Technical Forum 5 01-18-2009 04:54 PM
Weber Carb.? clarkjdg YJ Wrangler Technical Forum 5 08-11-2008 06:48 AM
Weber Carb spencer7000 YJ Wrangler Technical Forum 4 12-13-2007 10:06 AM
Weber carb help rockkayak YJ Wrangler Technical Forum 4 05-20-2005 01:01 PM
