weber carb rough idle - JeepForum.com
post #1 of 3 Old 06-04-2003, 05:19 PM Thread Starter
mv971
Does anyone have a clue what could be the prob. I had a weber carb installed a year ago on my 89 4.2liter ran fine now when its cold or intermittently the idle is very rough but not all the time mostly cold ,has anyone had this prob was it choke related or is the computer still involved after installing a weber.thanx mike
mv971 is offline
post #2 of 3 Old 06-07-2003, 09:12 AM
Brooklyn
There is a product that replaces the air filter box. It looks like a tube that takes air from next to the exaust.
89', 258, TFI, Nutter, weber36
Brooklyn is offline
post #3 of 3 Old 06-07-2003, 12:59 PM
Meister_jeep
I've had the same problem as you since I live In quebec Canada its the coldest you can get in almost all north america and the answer is simple its choke related. A few weeks ago it was raining a lot around here and my jeep would die all the time until it was at operating temp. I solved the problem by adjusting the choke. A good way to adjust the choke is to warm up your jeep until it is really at operating temperture. Then when you choke plate is wide open loosen the 3 screws that hold your choke assembly and start to rotate the choke until the plate starts to move and close a tiny bit and screw it there. I say this is because if you follow the instruction with your weber they say to wait until it is warm and then loosen your choke until the plate is wide open. If you get cold weather you want the choke to stay on the longest until the engine is warm so if you adjust the choke like I told you to you will have you choke on the longest until the engine is warm and then it will be fully open also.
hope it helps you out a little
1988 YJ 4.2l
__________________________________________________ __
WEBER CARB
NUTTER BYPASS
FIBERGLASS BODY TUB
BDS 3.5
SYE+CV SHAFT
FORD 8.8 WITH 4.10 GEARS, DISK BRAKES
33x12.50 GOODYEAR MT/R's ON AR767 15x8
CUSTOM STANLESS STEEL DISCO`s
JUICEBOX.
LED TAIL LIGHTS
$10 homemade POSILOCK
(IN THE WORKS THIS SUMMER)
-Custom front and rear bumpers
-HEI UPGRADE
-4.0 HEAD
-MIGHT TRY THE JEEP INJECTION KIT FROM WEBER
Meister_jeep is offline
Weber Carb....Won't idle at all anymore! Do I need a fuel regulator???? saint152 YJ Wrangler Technical Forum 12 08-12-2012 06:39 AM
Weber Carb vs. Stand. Carb 89 YJ Beast89 YJ Wrangler Technical Forum 10 05-20-2012 11:38 AM
90 YJ 4.2L with weber carb and CRT HEI misses at idle, pings, and has NO POWER! Bigbluefan5 YJ Wrangler Technical Forum 11 04-27-2009 01:56 PM
Really Rough Idle: 1989 6cyl 4.2 Weber Carb. hillie4life YJ Wrangler Technical Forum 14 02-25-2009 02:03 PM
idle relays with no idle solenoid and replacement carb defmornahan YJ Wrangler Technical Forum 3 10-08-2008 10:24 PM
