Weber Carb for my 89??? - JeepForum.com
post #1 of 27 Old 09-04-2007, 06:20 AM Thread Starter
RAOTERO
RAOTERO's Avatar
Ok...not saying anything new, but the stock Carter Carb blows... I've heard from buddies that have them that getting a weber will solve some problems. This sounds a lot cheaper than going with an EFI conversion kit...If it works. Anyone smart on the issue? If this is a good sub...what kind of specs do you recommend?
'89 YJ
RAOTERO is offline
post #2 of 27 Old 09-04-2007, 07:48 AM
k12lts
We put the Weber 32/36 on my son's 90 YJ in April and did the Nutter bypass at the same time. The Jeep runs like new and no adjustments to the carb were necessary. Very simple bolt on job.
k12lts is offline
post #3 of 27 Old 09-04-2007, 09:13 AM Thread Starter
RAOTERO
RAOTERO's Avatar
Nutter bypass? what's that?
'89 YJ
RAOTERO is offline
post #4 of 27 Old 09-04-2007, 09:47 AM
MetZenDS
Bypasses the ECM so it will let the carb do its thing without jacking everything else up. You'll also have to change your timing.
check this out for the nutter-
http://home.sprynet.com/~dale02/ignmods.htm#diagram
1989 Jeep Wrangler YJ- PARTING OUT-
MetZenDS is offline
post #5 of 27 Old 09-04-2007, 08:42 PM Thread Starter
RAOTERO
RAOTERO's Avatar
http://www.webercarbsdirect.com/Carburetors_s/2.htm
Can you check this site out and give me some advice on what might work best.
'89 YJ
RAOTERO is offline
post #6 of 27 Old 09-04-2007, 08:47 PM
ElvisV04290
ElvisV04290's Avatar
This one, but not sure if it comes with the adapter plates you need
http://www.webercarbsdirect.com/32_3...22680.033b.htm
EDIT: This is what I got, came with almost everything, its the same thing as above but with the proper adapter plates
http://www.redlineweber.com/html/kits/k551.htm
1990 YJ, Colorado Red with 'Laredo' markings, 4.2L, TF999, NP231, Valvoline Syn fluids, Weber 32/36, Nutter Bypass, Dana 30/35, 16" Electric Fan, Optima Yellow Top, 140amp alt., K&N Air Filter, Cherry Bomb muffler, SRC Front Bumper, CH&F Shackles, KC 100w Daylighters, Homemade Lightbar, Rear Aux lights, Cobra CB/PA/WX, 102" Whip Ant., 400 watt power inverter, 2 fire extinguishers, Mobile Internet & WiFi equipped.
Daily Driver since April 23rd, 2003
Northern Illinois Extreme Jeep Club Member
Weber 32/36 Install ->
Early YJ Club Member #37
For anyone with a 4.2L -->
ElvisV04290 is offline
post #7 of 27 Old 09-04-2007, 08:51 PM
rebuiltyj
rebuiltyj's Avatar
1987 YJ Wrangler
i put a weber 34 on and did the nutter and it helped alot. i was messing with my jeep every weekend trying to get it running good and i havent touched the engine since i put the weber on other than opening up the jets.
rebuiltyj is offline
post #8 of 27 Old 09-04-2007, 08:52 PM
ElvisV04290
It looks like that website you linked to does have a converson kit, but its like $350, I think I got mine from redline for $250.
post #9 of 27 Old 09-04-2007, 09:00 PM Thread Starter
RAOTERO
RAOTERO's Avatar
Man talk about timely straight forward advice...How much did you drop on it? I didn't see prices
'89 YJ
RAOTERO is offline
post #10 of 27 Old 09-04-2007, 09:09 PM
rebuiltyj
rebuiltyj's Avatar
1987 YJ Wrangler
i spent about 300 on the carb from quadratec then i got a mr gasket fuel regulator for around 30 i think from advanced. so about 330 is what i spent.
post #11 of 27 Old 09-04-2007, 09:24 PM Thread Starter
RAOTERO
RAOTERO's Avatar
I think the very first thing I did when I got my heep was replace the carb with another stock carter carb...but an older one(one for a CJ) to eliminate the electric part on the back. So does the electric choke on that redline carb force me to hook it up again?
'89 YJ
RAOTERO is offline
post #12 of 27 Old 09-05-2007, 07:02 PM
rebuiltyj
rebuiltyj's Avatar
1987 YJ Wrangler
you dont need to plug the big connector thats on the back of the carb. the electric choke is run off a single wire and connects on the passenger side of the carb or the side near the valve cover.
post #13 of 27 Old 09-06-2007, 10:40 PM
czachorj
All of this is very good advice (advice I went off of actually....), but mine required much more work after the Weber - found out I needed more fixed and was just hitting the "tip of the iceberg". After the Weber, I ended up replacing the fuel lines, fuel filter, ignition coil, spark plugs, plug wires, cap and button and finally turned out to be the distributor - NOW it runs like a top......
Just an FYI that the Weber may not be the answer to your prayers like I thought it would be for me......
Jason
czachorj is offline
post #14 of 27 Old 09-07-2007, 11:22 AM
giggityjeeper
Jason
It will answer A LOT or your prayers, looking back I would NOT have done nothing until I had put the weber on, the Carter will never run right an will aggrevate you till you finally get mad enough to do something stupid like sell your jeep, I almost did.....finally spent the 365 shipping included to Canada....and 3 hours in the driveway, and POW, fired up first time, and never missed a beat since, I to had to change the Dist, and wires and plugs, but the weber just higlited the other problems cause it was at least finally wanting to run.....runs like a top now
on that note also I did the posi lok to get rid of more vacuumcrap, so now I only have 3-5 vac lines under the hood, instead of the speghetti platter it was with the carter...
Started with some rust repairs ended in a SOA...
family roll bar swap/upgrade..
1990 YJ. SOA, OME 36R 3.5" lift springs, OME 5/8 greasable shackles, OTT high steer, Custom cage, team Rush, Posi, 33 TSL swampers
giggityjeeper is offline
post #15 of 27 Old 09-07-2007, 10:32 PM
jarhead2531
Just an opinion, but have you considered a motorcraft 2100 for a carb? I've had both a weber and a MC on my '90 4.2 with 4.0 head conversion and though the Weber runs great (once it was tweaked and fuel pressure regulator installed), I never thought that the MC was a bad alternative-rock solid running at just about any angle, no computer interference, relatively easy install with little to no tweaking, and most importantly CHEAP!!! I got my hands on a Weber from a friend and I wanted to try it out which was the only reason I took off the MC. I keep it as a spare in case the Weber ever craps out.
jarhead2531 is offline
Weber Carb vs. Stand. Carb 89 YJ Beast89 YJ Wrangler Technical Forum 10 05-20-2012 11:38 AM
Help with weber carb vetterM3 YJ Wrangler Technical Forum 16 07-02-2008 10:14 AM
Weber Carb 32/36 brianfa73 YJ Wrangler Technical Forum 3 04-30-2008 11:35 AM
Weber Carb Help Jeep1921 YJ Wrangler Technical Forum 2 04-20-2005 08:39 AM
Need help with my weber carb dcbeer YJ Wrangler Technical Forum 4 08-24-2002 07:41 AM
