weber carb idle issue - JeepForum.com
post #1 of 3 Old 01-08-2012, 08:36 PM Thread Starter
goreboy8
1987 YJ Wrangler
Hello everyone, i installed the weber carb and can't seem to figure out why my idle speeds up when the engine is warm and slower when it is cold.
When the engine is cold it idles at around 500 RPM and when warm at around 900-1000 RPM.
Can anyone please help?
Thank you in advance
4.2l I6
goreboy8 is offline
post #2 of 3 Old 01-08-2012, 09:45 PM
mcmud
1983 CJ8
You have two idle speed screws, a fast idle that should be in play while the choke plates are closed and or during some time while they are opening. The other is the Curb idle speed screw, both control the throttle plate position.
If your fast idle speed screw is set too shallow to reach the fast idle cam or so deep that it cannot 'climb' onto it, either will prevent the function that was intended, faster idle during the warmup.
Likewise the Curb Idle speed screw set too deep could allow the same issue... choke plate in play= slow idle, choke plate open=faster idle speed, if the fast idle screw is out of position.
The cure is to set the screws.
Which "Weber" have you mounted?
mcmud is offline
post #3 of 3 Old 01-09-2012, 07:55 AM Thread Starter
goreboy8
1987 YJ Wrangler
i have the WK551-34
goreboy8 is offline
carb , idle , issue , slow , weber
Weber Carb....Won't idle at all anymore! Do I need a fuel regulator???? saint152 YJ Wrangler Technical Forum 12 08-12-2012 05:39 AM
If I crack open the top of my Weber carb, my idle issue disappears??? unlucky YJ Wrangler Technical Forum 5 07-23-2011 06:29 PM
90 YJ 4.2L with weber carb and CRT HEI misses at idle, pings, and has NO POWER! Bigbluefan5 YJ Wrangler Technical Forum 11 04-27-2009 12:56 PM
weber carb rough idle mv971 YJ Wrangler Technical Forum 2 06-07-2003 11:59 AM
