Weber carb ID ? - JeepForum.com
post #1 of 2 Old 09-25-2009, 07:58 AM Thread Starter
vector6
Weber carb ID ?
how exactly do i identify the Weber carb on my kids 89 YJ ?
is there a tag on the carb somewhere?
vector6 is offline
post #2 of 2 Old 09-25-2009, 10:55 AM
mcmud
1983 CJ8
If it is really a Weber carb the Series (model) identification will be stamped into the base of the body at the mounting flange on the end that is opposite the choke assembly.
If it looks somewhat similar to a Weber but there is no stamping located there, it is a Solex being marketed as either the 'weber' DGEC 34/34 or possibly the DGEC 36/36.
If it is a Carter/Weber and you find the name cast into the body at choke side of the carb and you find that it has a "stepper motor" attached at the rear of the carb it is the Carter BBD w/stepper.
mcmud is offline
Weber Carb vs. Stand. Carb 89 YJ Beast89 YJ Wrangler Technical Forum 10 05-20-2012 11:38 AM
Help with weber carb vetterM3 YJ Wrangler Technical Forum 16 07-02-2008 10:14 AM
Weber Carb 32/36 brianfa73 YJ Wrangler Technical Forum 3 04-30-2008 11:35 AM
Weber Carb Help Jeep1921 YJ Wrangler Technical Forum 2 04-20-2005 08:39 AM
Need help with my weber carb dcbeer YJ Wrangler Technical Forum 4 08-24-2002 07:41 AM
