Weber Carb. - JeepForum.com
post #1 of 3 Old 08-17-2008, 07:55 PM Thread Starter
zekthecat
Weber Carb.
Ok can someone tell me if I can route all the lines into one that goes into the valve cover? I want to route them all to the back of the cover is that possible or do I need to have two lines?
zekthecat is offline
post #2 of 3 Old 08-18-2008, 12:14 AM Thread Starter
zekthecat
Bummppied bump
post #3 of 3 Old 08-18-2008, 06:23 AM
King03Kev
King03Kev's Avatar
1987 YJ Wrangler
At first look the line for your brake boost is wrong, connect this to the plug below the carb coming out of intake to the drivers side. The port in front of carb you have hooked to now should be for vacuum advance. It looks like you may want to reread install instructions completely. Good luck.
kevyj87 '87 I6 5spd, 215,000+ miles, Herced, Nuttered, Weber, HEI, RE 4", 1" BL, 4:11's, np231, 33x12.5's, SYE & shaft, 1" brown dog mm, home made bumpers front & rear, Ramsey 8,000lb winch
King03Kev is offline
Weber Carb vs. Stand. Carb 89 YJ Beast89 YJ Wrangler Technical Forum 10 05-20-2012 11:38 AM
Help with weber carb vetterM3 YJ Wrangler Technical Forum 16 07-02-2008 10:14 AM
Weber Carb 32/36 brianfa73 YJ Wrangler Technical Forum 3 04-30-2008 11:35 AM
Weber Carb Help Jeep1921 YJ Wrangler Technical Forum 2 04-20-2005 08:39 AM
Need help with my weber carb dcbeer YJ Wrangler Technical Forum 4 08-24-2002 07:41 AM
