Weber Carb.? - JeepForum.com
post #1 of 6 Old 08-10-2008, 08:40 PM Thread Starter
clarkjdg
clarkjdg's Avatar
Weber Carb.?
OK Guys I've got a 87 YJ and that stock @#%* carb is gone and I guess the Weber is the way to go from what Ive heard. Im not a hot rod so is a 32 DGEC big enough? I konw a bunch of you guys have done this so please give me a helping hand here please. I know the pressure regulator is a must for MPG.
LIVE EVERY DAY LIKE IS WAS YOUR LAST...
/_|__\___\
[n___n_[*lllll*]
(o) )-(o) )-*-) )
88 YJ, Smittybilt SRC Front, Side, and Rear Armor, Family Roll Bars, TJ Flares, and Half Doors
4"Leaf, 2"Body, and 1"Leaf Lift, 4.10 Geared Dana 30 Posi with Cable Engage, Ford 8.8 Posi, With 33s BFGs MT KM2
Everything "Black" Inner, Under, and outer "Black" on the Body is "Bed Linered" and I will be Thru the day that I Die!
clarkjdg is offline
post #2 of 6 Old 08-10-2008, 09:29 PM
Jblood
yep, i put the 32/36 in mine back in January, and its been working great ever since, smoothed the idle and all other problems right away. Also I found carbs unlimited had the cheapest price on any Weber I had seen. As for the pressure reg I had mine set at suggested psi and it killed two fuel pumps, so I nixed the whole thing and i haven't noticed a difference. the 32/36 is for a little quicker acceleration and top speed due to its progressive set up and the 34/34 is more for low end torque but a lot of people have had very desirable results from both kits
also this link was very helpful to me
hope it helped
-John
Originally Posted by JeepEngineers View Post
We set the benchmark. Period.
If you're not driving a Jeep, then **** you! -texasdog
Yeah I wanna pay top dollar for inexperience! That's why I take my Jeep to the dealer for service - vadslram
i have a sahara and wheel the piss out of it - JimKuback
Crashing usually happens without prior notice. That is why it is usually referred to as an accident. Actually, it is quite sudden in most cases. - GeneralDisarray
Jblood is offline
post #3 of 6 Old 08-10-2008, 09:32 PM
jeepercreeper77
jeepercreeper77's Avatar
i have a 34/34 interco weber and it works really well.i'm still tinkering with it but it's worth it.you have to use the pressure regulator because the carb operrates at 2.5 to 3.0 psi. if you run it higher it will run richer.search around alittle you'll get lots of info.
90 wrangler,4.2l,1" MML,CRT HEI Dist.,34/34(interco) weber, hurst shftr,5spd,5" BDS lft,f-d30/r-8.8,5/8 lft booms,1" bl,tflex belly up,JB convs. SYE,gdyr mtr35s,hurc'ed,smit src frt bump,gen-r rear bump w/tire carrier,f&r tube fenders,psc knokrs,r gen-rgt ful conr gurds,duel bat.,BIC,m8000
jeepercreeper77 is offline
post #4 of 6 Old 08-10-2008, 10:04 PM
4.7stroker
Look into the Motorcraft MC2100 swap.
It is Much cheaper just as reliable plenty of knowledge on the carb.
Dwayne
[url]
Prevent Flat Tappet Cam Failure.
[url]
4.7stroker is offline
post #5 of 6 Old 08-11-2008, 05:38 AM
JaikYJ
Hey I bought my jeep stock with the carter carb. The first thing I did was replace that piece of **** with the weber 32/36. Right out of the box there was a noticable difference. I never knew my jeep could sound the way it did that first run down the road with it. The set up with the open air filter is great. When you put the pedal down you can hear the second barrel open right up and the pick up was amazing. Best investment I've made on my jeep. I run a pressure regulator I have mine at 2 for regular driving, and 1.5 for offroad. Keep in mind each engine wears differently so play around with the regulator alittle bit to find whats best for you. I never would have guessed that my 87 had all that power waiting to be set free. I think you will be happy with weber.
87 YJ(sold), 97 TJ(sold), 99 TJ(daily)
03 R1 (fun)68 Mustang Coupe(summer)
67 Fastback(resto)
JaikYJ is offline
post #6 of 6 Old 08-11-2008, 06:48 AM
xxxflhrci
xxxflhrci's Avatar
I love my Weber 32/36. I have driven it with and without a regulator and can't tell any difference.
xxxflhrci is offline
Weber Carb vs. Stand. Carb 89 YJ Beast89 YJ Wrangler Technical Forum 10 05-20-2012 10:38 AM
Help with weber carb vetterM3 YJ Wrangler Technical Forum 16 07-02-2008 09:14 AM
Weber Carb 32/36 brianfa73 YJ Wrangler Technical Forum 3 04-30-2008 10:35 AM
Weber Carb Help Jeep1921 YJ Wrangler Technical Forum 2 04-20-2005 07:39 AM
Need help with my weber carb dcbeer YJ Wrangler Technical Forum 4 08-24-2002 06:41 AM
