Weber carb on a 4.5 stroker - JeepForum.com
post #1 of 2 Old 04-11-2010, 11:59 PM Thread Starter
55jeepskeet
Let me start off by saying I love my carb'ed motor. So with that being said has any one biult a 4.5 stroker using a 4.0 block with the 4.2 rods an crankshaft and been able to keep using there stock 4.2 exaust and intake manifolds and there weber carb? Question two can I use the 4.2 cam shaft? This will be my first stroker biuld so any additional info would be great.
55jeepskeet is offline
post #2 of 2 Old 04-12-2010, 12:00 PM
wendell
1987 YJ Wrangler
To get the best benifit from your stroker, I would go with the offy intake and holley TA 4 barrel and a header. I would also recomend comp cam X4250H for a screaming stroker. I installed these parts on my 258 witha 4.0 head swap and it was like a different engine, I don't miss a V-8. You don't have to add these parts to your stroker, however, why not get the most from your stroker now that you have went to the trouble to build a 4.5, get all the power available.
1987 wrangler, 258 I-6, 5-speed.
2007 liberty sport 4X4, automatic
2009 ford ranger 4x4 FX4 OFF/ROAD, 5-speed
wendell is offline
4.2 , 4.5 , stroker , weber
Weber Carb vs. Stand. Carb 89 YJ Beast89 YJ Wrangler Technical Forum 10 05-20-2012 10:38 AM
Carb(s) on a 4.7 stroker? Pittsbuilder YJ Wrangler Technical Forum 2 01-24-2009 08:37 AM
Weber Carb Help Jeep1921 YJ Wrangler Technical Forum 2 04-20-2005 07:39 AM
? about Weber Carb 87 JEEP YJ YJ Wrangler Technical Forum 2 12-25-2003 04:24 PM
Need help with my weber carb dcbeer YJ Wrangler Technical Forum 4 08-24-2002 06:41 AM
