weber carb??? - JeepForum.com
post #1 of 10 Old 11-23-2011, 02:33 PM Thread Starter
AmmitOsiris
AmmitOsiris's Avatar
weber carb???
Does weber have a computer controlled carb?
AmmitOsiris is offline
post #2 of 10 Old 11-23-2011, 04:56 PM
mekken
Nope only thing electric is the choke unless you get a manual choke. The wire is there already so I got the auto choke. Awsome carb btw 3 years strong with mine.
mekken is offline
post #3 of 10 Old 11-23-2011, 07:10 PM Thread Starter
AmmitOsiris
So its like the carter then? And if so it adapts to the stock air cleaner right??
post #4 of 10 Old 11-23-2011, 09:16 PM
Jax89Jeeper
Do some research on the weber vs mc2150... Most say the weber is a PITA to tune, and I agree. I have the MC2150 which IMO is the better carb and is much easier to tune.
Jax89Jeeper is offline
post #5 of 10 Old 11-23-2011, 09:49 PM Thread Starter
AmmitOsiris
Well I'm just wondering because I'm in cali, but I passed with a weber carb, confused? ???
post #6 of 10 Old 11-23-2011, 11:42 PM
Jax89Jeeper
Yeah, Cali is a PITA... I live in FL with no emissions testing, makes life much easier with my Jeep for sure.
post #7 of 10 Old 11-24-2011, 05:53 AM
DAVE4273
they have an adaptor that will allow for the stock air cleaner assembly. Happy thanksgiving
David
DAVE4273 is offline
post #8 of 10 Old 11-24-2011, 07:56 AM Thread Starter
AmmitOsiris
Thank you and happy thanksgiving to all
post #9 of 10 Old 11-24-2011, 09:17 AM
NonRubicon
CA laws cover emissions and equipment. Enforcing the equipment part usually just depends on who is doing the visual inspection. I took my YJ to one station to get it smogged and the tech checked the cat for a CARB EO. Unhappy with the service and results at that station, after making repairs/upgrades I had my YJ smogged at a different place and the tech did not check for the EO on the cat, and let me slide on not having a PCV line hooked up properly. He did however look very closely at the EO sticker for the Howell TBI that I put in and made sure that everything was hooked up according to the vacuum line diagram. Not every smog check station is equal.
The weber you have is apparently tuned well enough to pass the sniffer, and it was smogged at a station that either didn't know what the true OEM setup is, or simply overlooked the fact that the carb wasn't stock. A properly tuned aftermarket carb can pass CA emissions (sniffer test) on the 4.2L YJ, it usually just fails the visual inspection for not being OEM.
The only CA legal carb for the 4.2L YJ is the OEM Carter BBD, with all the bells, whistles, vacuum lines and computer.
Better hope you don't get pulled over by a savvy cop looking to rack up fines for illegal equipment. You can get fined for having a Weber on your 4.2L YJ here in Cali.
NonRubicon is offline
post #10 of 10 Old 11-24-2011, 09:24 AM Thread Starter
AmmitOsiris
Aww snap that's not good.... well then I'm going to ake a picture of the carb and you guys tell me, because someone told me its a weber....
