Weber air cleaner adapter - JeepForum.com
post #1 of 3 Old 06-25-2002, 05:10 PM Thread Starter
johny1i
johny1i's Avatar
Just installed a new Weber over the weekend and bought the optional adapter that allows you to use the stock air cleaner assembly for cold air intake (bought it all from Carbs Unlimited--carbs.net). Have any of you guys used this setup? I tried it both ways today at speeds up to 80 mph and I really didn't see a difference--I think the added flow of the square weber air filter balances out the cold air of the stock setup. Anyway, I think I'm going to send the adapter back, but I was just wondering if anybody saw a real difference/advantage that might entice me to keep it (I don't think it's worth the extra $30).
Currently an '86 CJ-7 and a '77 CJ-7 Golden Eagle---#4 and 5 following a '01 Sahara, '90 Sahara, and '85 CJ-7....
johny1i is offline
post #2 of 3 Old 06-25-2002, 05:31 PM
dcbeer
I found it is good for cold weather. Helps with the warm-up process. However, living in Florida I would think it is not needed. I would just stay with the small base and K&N filter.
1988 yj, computer bypass, webber carb and the ever famous BA10/5 transmission (if you have one you know it or will find out).
dcbeer is offline
post #3 of 3 Old 06-25-2002, 06:25 PM
Charlie L
One advantage that comes to mind is that the stock assembly may help keep mud and water out of the carb a little better. I know that the square filter is oil coated and can be cleaned, but it's a little harder for mudd to travel up the inlet on the stock assembly.
Just a thought
Charlie
87 YJ, Wilderness Safari Rack
31/10.50 BFG's on 15X8 Atlas wheels, 1.25" shackle lift,
Weber Carb
Charlie L is offline
Stock Air Filter Adapter For Weber BigOrange90YJ YJ Wrangler Technical Forum 2 12-18-2009 07:48 AM
Weber 32/36 DGEV adapter gaskets laffman YJ Wrangler Technical Forum 1 09-15-2009 10:37 AM
Weber 4106 adapter plate jgowen YJ Wrangler Technical Forum 2 09-16-2007 05:26 PM
Weber adapter plate install todnshay YJ Wrangler Technical Forum 10 01-17-2006 12:03 PM
weber air cleaner Meister_jeep YJ Wrangler Technical Forum 3 09-02-2003 10:36 PM
