Weber 32/36 questions - JeepForum.com
post #1 of 10 Old 07-15-2013, 03:27 PM Thread Starter
rocketboy
rocketboy's Avatar
I have a Weber 32/36 that I purchased from WeberCarbsDirect.com. Here is a picture with a logo.
Does this mean I have a "fake" Weber? I remember reading on one of these threads where the carbs from Weber Redline were real Webers and the ones from Weber Carbs Direct were fake. And that the real ones have logos cast into the metal whereas the fake ones have a label.
Is this correct?
rocketboy is offline
post #2 of 10 Old 07-15-2013, 03:38 PM
superj
You need the cast weber sign. Does it work well? The really nice webers are made in spain
I don't feel like working on anything at this time so i sold my yj.
superj is offline
post #3 of 10 Old 07-15-2013, 04:04 PM Thread Starter
rocketboy
rocketboy's Avatar
The reason I bring this up is that it failed emissions today here in Texas. HC level was to high indicating it's running rich.
Whenever I run the lean best idle procedure I run into the situation below in bold:
"If the mixture screw is more than 2-1/2 turns out turns then the Idle jet is too lean (too Small). When the mixture screw is less than 1-1/2 then the Idle jet is too rich (too large). These assumptions are based on the fact that the speed screw setting is not opened more than 1-1/2 turns. If the speed screw has to be opened 2 or more turns then this is also an indication of a lean condition usually requiring greater change. At times it may appear to be showing signs of richness or flooding it is really a lean condition. "
So, the carburetor has always run well, but no matter which idle jets I put in I can never get it to run with the speed screw set at 2 turns or less. I think technically it's running lean but I'm having to compensate by having the plate opened up dumping more gas in. My theory is that this is why I have high hydrocarbons.
Bottom line, the reason I asked if my carburetor was not a "real" Weber is that I'm concerned this carb isn't right and I'm never going to get it zero'd in. Perhaps I should bite the bullet and replace it.
post #4 of 10 Old 07-15-2013, 05:33 PM
roadyrob
1987 YJ Wrangler
heres a thread on setting up the weber, maybe it will help.
http://www.jeepforum.com/forum/f8/we...ssion-1051137/
atleast yours has the weber name on it. I had the weber clone put out by empi, a real piece of junk. got sick of constantly setting it and switched to a holley.
Do everything with a positive attitude, it won't always work but you'll piss enough people off to make it worthwhile.
the voices aren't real but they sure have good ideas.
roadyrob is offline
post #5 of 10 Old 07-15-2013, 05:56 PM Thread Starter
rocketboy
rocketboy's Avatar
Some other details about my situation:
Stock distributer, nittered;
Vacuum lines set up as follows:
Weber currently has a 75 primary idle jet and a 60 secondary idle jet;
Idle jets I have handy:
Primary - 70, 75, 80, 90
Secondary - 60, 65, 75, 80
post #6 of 10 Old 07-16-2013, 10:25 AM Thread Starter
rocketboy
rocketboy's Avatar
Thanks superj and roady rob.
I think after having this carb for 2 years and rejetting it multiple times, I'm going to go with the motor craft. It runs good but I've never gotten it optimized per the instructions and now I'm flunking the smog check.
The bad thing is it's the last smog check it will ever need since in TX it will be exempt when it turns 25.
post #7 of 10 Old 07-16-2013, 02:42 PM
superj
Use a vacuum gauge to set it instead. Search for vacuum gauges and instructions will show up on how to do it
superj is offline
post #8 of 10 Old 07-16-2013, 03:59 PM
superj
Also, can you inspect it in another county? We don't do emissions here in Nueces county.
I just left the inspection place with my new sticker. Luckily my jeep is an 87 so I can basically do as I wish.
superj is offline
post #9 of 10 Old 07-16-2013, 05:19 PM Thread Starter
rocketboy
rocketboy's Avatar
I'm pretty sure that since my registration sticker on the windshield says my county, the inspection station in another county wouldn't do it.
That'd be a pretty sweet loophole though!
___________________
1989 YJ - 4.0L
2001 WJ 4.0L
post #10 of 10 Old 07-16-2013, 05:54 PM
superj
Hmm, what if you were down on vacation and noticed it was out. Seems weird
superj is offline
