#31 | |
I am thinking EGR. My old Carter YF did not pull too much vacuum. In fact there was really no suction at all. I think with this new Weber the vacuum is so good that it has highlighted a bad EGR valve. it may be stuck part open. I hate to just change the part, but I may have to try it.
Was the lean / rich easy to tune. The last carb I had I could not really see any difference in the idle or how it ran no matter where the screw was adjusted.
#32 |
I have the same issue as well. I did the Nutter and it helped a little but it is still there. I can tell you that my EGR is shot and I do not know if it is open or closed. I think I have my fuel mixture correct although I am not 100% sure.
If someone can answer this I will be thrilled. |
#33 | |
1990 YJ, Colorado Red with 'Laredo' markings, 4.2L, TF999, NP231, Valvoline Syn fluids, Weber 32/36, Nutter Bypass, Dana 30/35, 16" Electric Fan, Optima Yellow Top, 140amp alt., K&N Air Filter, Cherry Bomb muffler, SRC Front Bumper, CH&F Shackles, KC 100w Daylighters, Homemade Lightbar, Rear Aux lights, Cobra CB/PA/WX, 102" Whip Ant., 400 watt power inverter, 2 fire extinguishers, Mobile Internet & WiFi equipped. Daily Driver since April 23rd, 2003 Northern Illinois Extreme Jeep Club Member www.extremejeepclub.com Weber 32/36 Install -> http://www.jeepforum.com/forum/f12/weber-32-36-install-write-up-382309/ Early YJ Club Member #37 For anyone with a 4.2L --> http://groups.jeepforum.com/258s_Unite |
#34 |
Can't help with the emissions stuff. I'm running holley ignition, blocked off EGR, and pretty much none of the other emissions equipment that came with the Jeep.
#35 |
I played with my fuel mixture this weekend and it seemed to help...
#36 |
Quick question (s):
1. The instructions made not mention of gasket sealer. Is this important, if I am not experiencing fuel leaks? 2. I am using the Weber air cleaner, which has no port to attach the aluminum foil exhaust gas recirc tube. Where should this foil tube go, now. If it is not needed, any suggestions for plugging the hole? |
#37 |
1. You want gasket sealer to keep it air and water tight. But you need to use a non-silicone or RTV sealer.
2. Not 100% on what you mean. Are you talking about the line that goes from the air cleaner to the PCV system? Maybe a picture of what you are talking about would help.
1990 YJ, Colorado Red with 'Laredo' markings, 4.2L, TF999, NP231, Valvoline Syn fluids, Weber 32/36, Nutter Bypass, Dana 30/35, 16" Electric Fan, Optima Yellow Top, 140amp alt., K&N Air Filter, Cherry Bomb muffler, SRC Front Bumper, CH&F Shackles, KC 100w Daylighters, Homemade Lightbar, Rear Aux lights, Cobra CB/PA/WX, 102" Whip Ant., 400 watt power inverter, 2 fire extinguishers, Mobile Internet & WiFi equipped. Daily Driver since April 23rd, 2003 Northern Illinois Extreme Jeep Club Member www.extremejeepclub.com Weber 32/36 Install -> http://www.jeepforum.com/forum/showthread.php?t=382309 Early YJ Club Member #37 For anyone with a 4.2L --> http://groups.jeepforum.com/258s_Unite |
#38 | |
Are you talking about the Pulse Air Tubes (2 thin tubes that connect the air cleaner to the exhaust pipe right after the manifold and the catalytic converter) or the large metal duct that connected the factory air cleaner to the center of the exhaust manifold?
'87 YJ Laredo - 4.0L, AX-15, NP231, 4.10s: 3.5" BDS, 31" Muds '95 XJ - Donated drive train to the YJ, Parting the rest out '51 CJ-3A - Buick 225 V6: Painless Wiring Harness, Warn Overdrive & Hubs, 2" Lift, 31" Muds |
#39 |
Pulse air system sounds more like it. I riped all that stuff out. And then folded the openings over on the exhaust pipe and the cat and then put high temp JB Weld stuff on 'em. Pluged them up real good.
#40 | |
The large metal duct, which looks like a dryer exhaust hose. It was attached to the bottom of the factory air cleaner box (4.2 straight 6), and exhaust manifold. The Weber air box does not have a spot for this duct, so I currently have it folded over, but it still spews exhaust gas (when the Jeep runs).
#41 |
I think that's the pre-heater for the carb, it should only be taking hot air off the manifold to heat the carb till the heat from the engine block can take over. It should not have a hole going into the exhaust, should just be a cover over the manifold. I have mine taken off, runs just fine, its really meant for winter to keep the carb from freezing over.
Correct me if im wrong Tshark
#42 | |
That is it, exactly! Don't bother covering it up? What about water, dirt, etc...?
#43 |
So you have the hot air hose (#24) coming off the air cleaner
![]() Going to a box (#19) on the exhaust manifold. ![]() That box over the exhaust is just an enclosure around the manifold. Take off the hose and the box, then make some modern art out of it or something.
#44 | |
Handy diagrams! Yes, 24 and 19. I'll remove all parts. Thanks!
#45 |
Nice work Elvis
| Thread Tools | |
Previous Thread
Next Thread
| Suggested Threads |
