Quantcast Weber 32/36 Install Write-up - Page 2 - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > YJ Wrangler Technical Forum > Weber 32/36 Install Write-up
Old 03-03-2007, 04:04 PM   #16
goatboy
Real nice write up!!! I was considering the Mopar EFI conversion, might do this one instead just to get it past smog out here in the Land o' Fruits, Nuts, and Tailpipe Sniffers! Hmmmm...reckon you can take that more than one way...
goatboy is offline   Reply With Quote
Old 03-03-2007, 06:10 PM   #17
My77cj5
Hey what a great write up. I have an EGR question on my 77 CJ 5. I have the PCV attached to the vacuum port on the adaptor plate and tee'd to the CTO and the purge on the charcoal canister. On the other port of the CTO I go to the EGR valve. Looking at the drawing should I be using the vacuum advance port to attach to the CTO?
I just did the weber conversion it's the 34 for the cater YF one barrel.
Thanks for you help
My77cj5 is offline   Reply With Quote
Old 03-03-2007, 06:30 PM   #18
ElvisV04290
Thanks for you help
I'm guessing the 77 CJ-5 has a 258 so I'll see how I can help. I have my hoses set up just as in the picture and it's all running great. I would think you would want the PCV hooked up to the manifold vacuum and the canister. If the engine is not running well, maybe try looking into redirecting your hoses? Good luck, sorry if this was of no help.
1990 YJ, Colorado Red with 'Laredo' markings, 4.2L, TF999, NP231, Valvoline Syn fluids, Weber 32/36, Nutter Bypass, Dana 30/35, 16" Electric Fan, Optima Yellow Top, 140amp alt., K&N Air Filter, Cherry Bomb muffler, SRC Front Bumper, CH&F Shackles, KC 100w Daylighters, Homemade Lightbar, Rear Aux lights, Cobra CB/PA/WX, 102" Whip Ant., 400 watt power inverter, 2 fire extinguishers, Mobile Internet & WiFi equipped.
Daily Driver since April 23rd, 2003
Northern Illinois Extreme Jeep Club Member www.extremejeepclub.com
Weber 32/36 Install -> http://www.jeepforum.com/forum/f12/weber-32-36-install-write-up-382309/
Early YJ Club Member #37
For anyone with a 4.2L --> http://groups.jeepforum.com/258s_Unite
ElvisV04290 is offline   Reply With Quote
Old 03-03-2007, 08:16 PM   #19
My77cj5
Thanks for the feedback. And again great info!
Old 03-03-2007, 08:19 PM   #20
offroadyjguy
I am running same carb on fresh 4.2 mine runs rich. Is it brcause of not having a fuel regulator?
89 YJ ISLANDER 4.2L
3 INCH RANCHO SPRING LIFT
31'S
offroadyjguy is offline   Reply With Quote
Old 03-03-2007, 11:54 PM   #21
ElvisV04290
I was told the YJ's fuel pump runs at 7 or 9 psi. I drove mine for 2 days without the regulator and it did run rich, but then again I did a poor initial tuning. I would get the regulator for the long run, but have you also checked your mixture settings or if they are OK, do you need to have different jets for it? The link in the write-up does a good job of setting the mixture and what conditions require re-jetting along with what size to go with. The Weber can take a maximum of 3psi, so like said, I would get the regulator anyways. Hope this helps.
Looks like I'm the Weber "go to" guy, keep the questions comming and I'll try to help anyone out.
Weber 32/36 Install -> http://www.jeepforum.com/forum/showthread.php?t=382309
Old 03-03-2007, 11:58 PM   #22
ElvisV04290
I would think the EFI would run cleaner than a carb since it mixes better, but I did pass Illinois emission laws with my Weber.
Old 03-04-2007, 01:20 PM   #23
My77cj5
Just an update. Hooked the hose up like the diagram. It is running great. Any idea why I might get a little back fire when I hit the gas in second?
Thanks
Old 03-04-2007, 01:32 PM   #24
sandman'sjeep
Hate to hijack this thread guys but would like your input...My DD 258 I6 87YJ has been using the weber for about 2yrs now. I've tried using a fuel regulator in the beginning but my Jeep always stalled out. I took it off and use the Carb just as is... Is there anything wrong with this... I followed the directions for the PSI and location where it should be installed...
Sandman
sandman'sjeep is offline   Reply With Quote
Old 03-04-2007, 01:38 PM   #25
offroadyjguy
I have been running mine for about 8 months it runs a little rich but no ill effects
89 YJ ISLANDER 4.2L
31'S
Old 03-04-2007, 03:06 PM   #26
ElvisV04290
Thanks
glad to hear its running better, is it a true backfire or just a pop with loss of power for a second and the picks up really fast?
When does it stall? At idle? Under heavy acceleration? Do you have the mixture set properly? mine ran really poor when it was not adjusted the right way first time around. Did the jeep run any better with the regulator removed? if not then I would keep it in and set it to 3PSI as the max, I think I'm running 2.5PSI now.
Old 03-04-2007, 04:12 PM   #27
bgredjeep
1987 YJ Wrangler
I ran mine for about 3 years before I installed a regulator (weber came with the Jeep and I knew nothing about it). A few of the things I noticed after the regulator was install are:
1. I don't smell like gas every time I drive the Jeep any more
2. No black smoke (gas) out the exhaust on heavy acceleration
3. It keeps running on steep climbs where before it would flood and stall
4. better throttle response at lower RPMs
bgredjeep is offline   Reply With Quote
Old 03-04-2007, 05:40 PM   #28
Tshark299
1987 YJ Wrangler
Thanks for you help
You'll want these vacuum lines connected to ported vacuum like the picture shows. Manifold vacuum will cause the canister to purge and the EGR valve to open at idle, which is not what you want. These events should only happen at part throttle.
hehe, i used to consider myself somewhat the same around these parts a couple years ago. The Weber was the first modification I made to my Jeep 2 weeks after I bought it, and it led me to learn how every fuel, ignition, and emission system for the 4.2L works in and out. I spent every day reading everything I could on these things, and then experimenting with my engine. I was obsessed! It's paid off though becauase literally the only time I open my hood now is to change the oil and top off fluids.
Excellent write-up, Elvis.
'87 YJ Laredo - 4.0L, AX-15, NP231, 4.10s: 3.5" BDS, 31" Muds
'95 XJ - Donated drive train to the YJ, Parting the rest out
'51 CJ-3A - Buick 225 V6: Painless Wiring Harness, Warn Overdrive & Hubs, 2" Lift, 31" Muds
Tshark299 is offline   Reply With Quote
Old 03-04-2007, 07:56 PM   #29
My77cj5
It is a pop with a loss of power. It happens under heavy acceleration. Could I have a bad EGR valve, maybe too much vacuum on the EGR? Or do I need to adjust the carb Lean / Rich. Timing and idle are good. Thanks in advance for your help
Old 03-04-2007, 08:11 PM   #30
ElvisV04290
I am having the same problem. I normaly don't put my foot to the floor, but when I have the very same thing happen. I was looking into it being an EGR problem but I don't know how to check it and see if its bad. I have the lean best setting on the carb. I don't know what to tell you. If anyone else has any ideas, feel free to post!
Glock Forum
EGGERS BROS. INC YOUR JEEP SOURCE
CALL 1-800-274-2460
Competitive pricing!
