weber 32/36 base plate and gasket question - JeepForum.com
post #1 of 3 Old 04-07-2012, 06:28 PM Thread Starter
bluedaffy
I have re-installed my weber 32/36 base plate and gaskets 3 times now! I spray the base with carb cleaner and I still have a leak!!!
The first two installs I cranked down the bolts using the weber gaskets that come with the kit.
This third time I made my own gaskets out of gasket cork that was a bit thicker than the weber kit gaskets & I pretty much just tightened everything until it felt firmly snug. The directions I read said to torque the first plate down to 12 ft/lbs and the second 6 ft/lbs. I do not have a torque wrench, so I have been just trying different strengths by hand to see what works, but the problem is, nothing has.
Two questions,
1. How much muscle should be put into tightening the base plate bolts? I know this is difficult to describe but an answer as simple as: Tighten until you can't tighten any more, or tighten until it's starting to get hard to tighten further would be sufficient for me.
2. The manifold vacuum port on the top base plate, is this fitting supposed to be flush? mine isn't quite flush and I'm scared that if I put anymore muscle into it, it will strip or something.
Thanks so much, and no I did not use gasket sealer, I've read not to more times then I've read I should.
bluedaffy is offline
post #2 of 3 Old 04-07-2012, 07:03 PM
roadyrob
1987 YJ Wrangler
do no over tighten the bolts, aluminum will strip. the plates might be warped, take a sheet of sand paper and lay it on a flat table and sand the plates till they are smooth. I put a light coat of grease on the gasket to help seal.
Do everything with a positive attitude, it won't always work but you'll piss enough people off to make it worthwhile.
the voices aren't real but they sure have good ideas.
roadyrob is offline
post #3 of 3 Old 04-07-2012, 10:16 PM
CB10101
^^ sand your plates flat and i used a thin coat of permatex #2 on the gaskets.
CB10101 is offline
carb , gasket , vacuum , weber
Carburetor Base Plate Twrecks YJ Wrangler Technical Forum 6 07-01-2011 06:14 PM
2011 Blue Ox Base PLate dbritsch JK Wrangler Technical Forum 6 10-07-2010 05:07 PM
Base Plate Question Oceanedge TJ Wrangler Technical Forum 4 12-13-2009 07:37 AM
Weber WEBWK551-36S base settings? mark12010 YJ Wrangler Technical Forum 4 07-13-2009 08:03 AM
base plate vs aftermarket bumper TJDaveX TJ Wrangler Technical Forum 0 12-19-2007 10:26 AM
