webe 32/36 float level? - JeepForum.com
post #1 of 5 Old 04-06-2013, 04:57 PM Thread Starter
lidlitalian
1987 YJ Wrangler
87 yj nuttered weber 32/36
Hey guys,
I just rebuild the carb and need to know what the float level for my rig should be set at. Its dumping way to much fuel Please help
Thanks in advance
lidlitalian is offline
post #2 of 5 Old 04-06-2013, 05:52 PM
Mean Max
Don't poke the bear
Mean Max's Avatar
Don't know if it's the same, but a Weber 38 spec is 18mm.
Max
Originally Posted by UltimatE View Post
Max has a picture of every Jeep part ever made.
Originally Posted by Benderff View Post
No one here knows what they are talking about. You should try Pirate 4x4 they will be happy to help you.
There is no situation that cannot be improved with a small but well-placed explosive.
Mean Max is offline
post #3 of 5 Old 04-07-2013, 07:58 AM
blown50
1987 YJ Wrangler
blown50 is offline
post #4 of 5 Old 04-07-2013, 10:33 AM Thread Starter
lidlitalian
1987 YJ Wrangler
Adjusted it to those specs. Now it seems I am getting way too much fuel as its filling up the sec barrel and literally squirting out of the carb. assuming the higher the float is set the more fuel it will dump into barrels??
post #5 of 5 Old 04-07-2013, 01:54 PM
blown50
1987 YJ Wrangler
How much fuel pressure u got, does it have a regulator? Webers hate fuel pressure, u may be overpowering the needle and seat! That drawing came strait from a weber service Manual, so I can't believe it would be wrong. I would check the pressure first and be sure there isn't to much!
blown50 is offline
