-   -   webe 32/36 float level? (http://www.jeepforum.com/forum/f12/webe-32-36-float-level-1505176/)
lidlitalian 04-06-2013 04:57 PM
87 yj nuttered weber 32/36
Hey guys,
I just rebuild the carb and need to know what the float level for my rig should be set at. Its dumping way to much fuel Please help
Thanks in advance
Mean Max 04-06-2013 05:52 PM
Don't know if it's the same, but a Weber 38 spec is 18mm.
Max
blown50 04-07-2013 07:58 AM
1 Attachment(s)
Attachment 602555
lidlitalian 04-07-2013 10:33 AM
Adjusted it to those specs. Now it seems I am getting way too much fuel as its filling up the sec barrel and literally squirting out of the carb. assuming the higher the float is set the more fuel it will dump into barrels??
blown50 04-07-2013 01:54 PM
How much fuel pressure u got, does it have a regulator? Webers hate fuel pressure, u may be overpowering the needle and seat! That drawing came strait from a weber service Manual, so I can't believe it would be wrong. I would check the pressure first and be sure there isn't to much!:)
The time now is 12:23 AM.
