Webber question? - JeepForum.com
post #1 of 4 Old 09-14-2011, 05:47 PM Thread Starter
frenziedYJ
Webber question?
I got a webber 36/36 dgec carb for my 1990 yj I6. the carb is amazing! makes a huge difference but every once and a while when i come to stop (i think its mosty on a stop with a decline) it has a huge idle increase and idles at about 2,100 RPM but if i tap the gas once or twice it goes back to normal. is this normal? i put a spring on the throttle to make sure it wasn't the throttle sticking, its not. any advice?
frenziedYJ is offline
post #2 of 4 Old 09-14-2011, 06:10 PM
mcmud
1983 CJ8
There is no 32/36DGEC and no, this increase in rpm is not normal.
It could be the result of unseen bind in the linkage, the throttle plate being pulled off center or possibly the choke linkage needs adjustment.
If you can identify this carb and or post an image to a photo host site and post the link to it here.
A pic including this return spring position/location would be helpful.
mcmud is offline
post #3 of 4 Old 09-14-2011, 09:15 PM Thread Starter
frenziedYJ
its not a 32/36. its a 36/36. http://www.quadratec.com/products/51312_58_07.htm
ill get a picture of it in the car for you tomorrow.
post #4 of 4 Old 09-14-2011, 09:16 PM Thread Starter
frenziedYJ
help needed , idle , vaccuum lines , weber , weber carb
webber issues the_barbarian YJ Wrangler Technical Forum 14 07-22-2009 12:38 PM
Webber !!!!! Josephrk24 YJ Wrangler Technical Forum 16 07-25-2006 05:50 PM
Webber k-551 AngeL0 YJ Wrangler Technical Forum 7 08-28-2005 04:18 PM
Webber 551 G-MAN YJ Wrangler Technical Forum 0 04-07-2004 09:39 AM
Webber Carb mitchj01 YJ Wrangler Technical Forum 1 08-09-2002 11:06 AM
