webber carb vacum problems - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > YJ Wrangler Technical Forum > webber carb vacum problems
Unread 04-11-2010, 11:23 AM   #1
jayhhaynes
carb was set up like this when i bought this jeep about 7 months ago. when i go wheelin, or any time i run it at high rpms the motor makes a loud sucking noise through the carburetor. It begins when i first give it a little bit of gas then begins to suck. if i give it around 50% throttle or it will rev up high then suck and do this repeatedly til i let off. if i hold it at around 10% it will make a loud sucking noise and shut off. if i try to drive like this it will jerk the jeep back in forth as i go down the road. I usually can get it to stop if i hold throttle at around 1000rpms right befor it dies then give it gas and there will be a loud pop coming from the carb and i can drive as normal.
this is my first carburetor and I'm still learning bout them.
thanks for your help
jayhhaynes is offline   Reply With Quote Quick reply to this message
Unread 04-11-2010, 12:05 PM   #2
PrinothPro
Whoa. First thing you must do is replace the filter! It look like it is clogged with dirt...
I noticed there is a hose just hanging out barely on left side of the choke, I would check that out. You should replace all the gaskets. They tend to rot out and create spots for air to suck in. I discovered my weber has one of the gasket half missing.
Is your jeep nuttered? Those webers do excellent when jeep is nuttered.
Also, welcome to the forum, you will find several good people on here who is very knowledgeable about weber more than me so they will come out and help you.
PrinothPro is offline   Reply With Quote Quick reply to this message
Unread 04-11-2010, 03:01 PM   #3
PoppaDucky
Here's a link to the thread I used to get my vacuum issues right. Keep in mind though that these are with a nutter bypass. I went ahead and replaced all my lines to eliminate leaks and used the diagram on post 23 to figure out what sizes I needed and where they ran. The diagram in post 26 shows the setup on a carb. http://www.jeepforum.com/forum/f8/we...96/index2.html
From the looks of it, you've got a 32/36 so here is a link to someone installing it from the beginning: http://www.jeepforum.com/forum/f140/...nstall-382317/
PoppaDucky is offline   Reply With Quote Quick reply to this message
