Weak brakes - JeepForum.com
post #1 of 5 Old 01-22-2013, 10:27 AM Thread Starter
zoltan
Weak brakes
Several months ago the brakes on my Jeep started getting weak where I needed to push harder on the pedal for the same effect. My mechanic quickly fixed it and said the rear brakes just needed to be adjusted. Now, it's started happening again, and I was hoping someone might have some idea why?
zoltan is offline
post #2 of 5 Old 01-22-2013, 11:11 AM
Mark05059
adjust them again. They wear out
1998 ZJ 5.2 Auto
1989 Wrangler Black Bone Stock 2.5l 5spd
/l , [____],
|---L--[]lllllll[]-
()_) ()_)==O=)_)
Mark05059 is offline
post #3 of 5 Old 01-22-2013, 11:21 AM
Jeepsr4me
Sounds like the booster or MC ORRRRR a soft line is clogging up and not letting fluid pass.
Jeepsr4me is offline
post #4 of 5 Old 01-22-2013, 12:13 PM
mrdeath2000
check your brake fluid. is it clear or dark? if it's dark its absorbed too much moisture and MAY need flushed. Brake fluid isnt really compressable, but when it absorbs moisture, it can now compress some creating a spongy or weak brake.
Above suggestions are also good things to check.
93' YJ 2.5L, 4.88's, 8.8, E-Locker & LSD
mrdeath2000 is offline
post #5 of 5 Old 01-22-2013, 05:19 PM
Ksyrium
1987 YJ Wrangler
Your YJ has rear drums, correct? Is your emergency braking acting similar to the main brake pedal?
If so, then there is a good chance that it is in the rear brakes and not the front.
I would also pull the rear drums off and check that the adjuster lever is stopping them from moving as it should. Maybe the adjusting lever spring has broken?
This will take you to a picture for more in depth look & part info.
Jeep4x4 Center Knowledge base
ΜΟΛΩΝ ΛΑΒΕ
Ksyrium is offline
