We Sprayed the whole thing.... - JeepForum.com
post #1 of 47 Old 11-12-2008, 10:10 AM Thread Starter
corvetteguy
We recently "Bedlined" the whole jeep....inside and out. As promised...heres some pics.
corvetteguy is offline
post #2 of 47 Old 11-12-2008, 10:12 AM
2005X
you really cant tell from the pics that the body was done , great job!!
2005X is offline
post #3 of 47 Old 11-12-2008, 10:14 AM Thread Starter
corvetteguy
The Before....
Previous owner has put over 3/8 inch thick bondo down the whole side!!....I ground it all off and realized it didnt even need it.....I used LESS then a golf ball size amount to repair the small dent that was needed.....
post #4 of 47 Old 11-12-2008, 10:35 AM
twomanyjeeps
Nice work...did you use a spray gun or rattle can it???
twomanyjeeps is offline
post #5 of 47 Old 11-12-2008, 10:38 AM Thread Starter
corvetteguy
Used Raptor system. Uses a special gun....VERY pleased with the results. Took the Jeep into the woods and surface didnt even get a mark. Holds up excellent.
post #6 of 47 Old 11-12-2008, 11:04 AM
Opihi59
from here it gets rough
Opihi59's Avatar
That certainly looks very nice. Likely spent a week of prep or more then about an hour putting it on........I'm willing to bet you had a difficult time coming up with white and gray liner. Well, maybe not--you live in Atlanta (center of the universe) Was it Herculiner or another product?
Good job.
....I'm not smart, but I can lift heavy things.......
Fill out your PROFILE, and don't forget to look in the FAQ for writeups
I'm stuck on da Rock
Originally Posted by Brian4.2 View Post
We will be going Metric every inch of the way.
Originally Posted by 40dog View Post
yes I'm a some guy and have always put gasket sealer on my surfaces before mating
Originally Posted by Virjeep View Post
You should go to Pirate. I hear they are real smart over there. You'd fit right in.
Opihi59 is offline
post #7 of 47 Old 11-12-2008, 11:49 AM
srad711
2003 WJ
I like it
I like it give us more details on prep and products used.
Thanks
srad711 is offline
post #8 of 47 Old 11-12-2008, 12:02 PM Thread Starter
corvetteguy
Thanks
Its UPOL Raptor Liner.....
As far as prep, i removed anything removable....then ground body to bare metal with 80 grit roloc discs. Then I primed entire veh with non sanding epoxy primer...several coats.
Then Tinted the liner the color I wanted....In this case black for the inside as well as the bumpers and A sand/kakhi for the ouside....has a light tan color. Does look more white in the above pics, but in person it is very yellow/sand/tan....kinda like a pair of kakhi pants or manilla folder.
Has a perfect texture. If i ever get rid of this jeep and get another jeep this will be the first thing i do to it.
now on to the lockers, tires, metal flares and winches......
post #9 of 47 Old 11-12-2008, 01:31 PM
twomanyjeeps
Very cool, I might have to thing about that instead of paint.
post #10 of 47 Old 11-12-2008, 01:38 PM
WranglerRush
That looks REALLY good. I also might do that instead of paint. How much are the Raptor kits? Did you get it at Pep Boys or somewhere like that?
1992 Red YJ 4.0 with 5 on the floor and 33's
WranglerRush is offline
post #11 of 47 Old 11-12-2008, 02:00 PM Thread Starter
corvetteguy
I Manage a dealership and our body shop ordered the kits from our paint supplier. they make two different kinds. one black, and one tintable. they are about 125.00 each. to do inside and out you will need approx 1 and half kits...
the kits have 4 bottles each. like i said you will need 6 bottles. If just doing the outside...1 kit is enough. It mixes and sprays very easily and is able to be recoated later if needed. If you order it, use the tintablekits and you can mix in any color base you would like
materials list:
3 quarts of epoxy primer and hardner if you like....
1 kit for outside
half quart of base color of your choice...per kit
another kit for inside and you will have 2 bottles left over for later if you needed
each it comes with a reuseable gun.
We spray these kits in back of pickups all the time as bedliner and have no issues. its VERY though stuff and works great.
post #12 of 47 Old 11-12-2008, 05:16 PM
OneCleanYj
Looks great I dig the white with the black interior.
92 YJ. Lifted, rubbered, geared, and more
OneCleanYj is offline
post #13 of 47 Old 11-12-2008, 07:27 PM Thread Starter
corvetteguy
Thanks....but its actually
<---this color
post #14 of 47 Old 11-12-2008, 08:13 PM
Cyborg
looks good.
One thing I would like to know, from your pictures (besides the close-up) we cant even tell that it is lined - good! In person, how close do you actually need to be to tell there is a definate texture.
Also, when you get it dirty, I wouldn't mind some more pictures of that, and an opinion how hard it was to clean.
Cyborg is offline
post #15 of 47 Old 11-12-2008, 08:18 PM Thread Starter
corvetteguy
Depending on how light hits it or what angle you view it ide say you can tell 6-8 feet away pretty easily.
ive had it in mud already....rinse off and use bristle brush to scrub any needed spot and it comes right off...material has a slight sheen to it.
Sprayed Cam Pos. Sensor w/ H2O and now it won't start... Need HELP!! ElJaynocibuR TJ Wrangler Technical Forum 4 01-19-2010 09:03 AM
just sprayed almost all the underside of my jeep with WD-40 incagoldjeep TJ Wrangler Technical Forum 23 12-10-2009 06:11 PM
Sprayed on lining before rocker installation? ironbelle TJ Wrangler Technical Forum 4 04-24-2005 12:40 PM
Durabak liner sprayed rgwjeep TJ Wrangler Technical Forum 0 06-02-2004 09:01 AM
sprayed on liner for tub? Kraemer TJ Wrangler Technical Forum 10 01-01-2004 07:51 PM
